automatic steering column problems
A place for new members to introduce themselves
ian1967
Post by ian1967 »
hello newly joing, awesome information here sick trucks too!
i just recently got a 67' f100, and my automatic column shift lever can shift out of park in to any gear but reverse, and when i put it back in park or any other gear higher than the previous gear it doesn't engage the tranny link. slips in the column? broken column? what parts or a complete rebuild? tranny is find, i manually shifted in gear and works fine, drive and reverse, what do i need to fix this problem , thanks :cry:
Re: automatic steering column problems
ian1967 » Tue Nov 15, 2016 10:23 pm
One thing to look at that is a constant issue with our trucks is the cab mounts. When they rust out they cause the truck to "settle" or shift causing linkage issues.
Are you saying it goes into reverse when shifted by hand at the transmission-but not by the shifter inside the cab? :hmm:
Mancar1
Post by Mancar1 »
Welcome aboard from Tehama Co, Ca
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
:wel: from Georgia!
