Hello from Phenix City, AL
A place for new members to introduce themselves
Geographer
Post by Geographer »
Hello everyone. I'm picking up this little gem, but research has left me a little confused.
Pretty much everything makes it look as if this is a 1970 F100 Explorer Special, except that the steering wheel looks like a '71/'72 steering wheel. I know that it might've been replaced. Also, even though Ford didn't use 351 Windsors in it's trucks, this engine looks very much like a 351 Windsor(extra set of intake bolts up front, and the "351 2V" sticker on the air cleaner...
The VIN is straight-up 1970, but I can't figure out how a "J" color-coded truck(Heavy Truck Red) could appear to be original light blue. Also, the interior code of "1 4" doesn't even exist on the interior code tables I've seen.
I'm wondering if sometime in it's past this truck had it's VIN plate replaced, and that's starting to worry me. I'm wondering if anyone could help me figure this out. I've included pictures!
71PA_Highboy
Re: Hello from Phenix City, AL
Post by 71PA_Highboy »
Welcome.
Check the frame VIN against the door VIN against the title VIN... the frame matters most.
As for the 351, an easy swap if it had a 302 originally.
Best of luck to you!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
popeyes71
Post by popeyes71 »
:wel: from California! :yt: that's what I would do. Yeah it if your truck originally had a small block, it would have been very simple to swap in a 351W at some point. The steering wheel is from a newer model Ford truck; possibly 80's. :fr:
-Popeye-
1971 F-250 4x4 Highboy
the elder rocker
Post by the elder rocker »
Hey! Fairly new here. Great info on this site. These guys are the Gurus! I was raised in Columbus, right across the river! :wel:
lennyp
Post by lennyp »
:wel: from Massachusetts.
hdman90
Post by hdman90 »
It looks to me like you have a 1970 Explorer package in "Grabber Blue". I believe sometimes the Explorer colors were specific to light trucks only and used the same color codes as some of the heavy truck colors; so it depends on what chart you are looking at.
Here is a color chart with the color you have:
https://www.google.com/search?q=1970+fo ... xI3PFyKzUM:
We ran into the same issue with my dad's '70 explorer green.
It looks to me like your truck came stock with Explorer option "C" or "D" depending on if it has power steering/brakes.
See more on the Explorer packages here:
http://fordification.com/tech/explorer.htm
As far as the steering wheel and engine goes, who knows, those were very commonly switched and swapped out.
Best of luck and keep us updated with what happens with your truck!
hdman90
Post by hdman90 »
Oh, and also, your interior has definitely been redone. The dash pad and seat have been recovered.
But I do believe those floor mats were either some sort of factory/dealer option, or a very cool aftermarket buy! There's a local junk yard with a truck that has the same floor mat, but its all deteriorated to pieces, or I would grab it!
Very cool to see another explorer still alive! :thup:
Geographer
Thank you each for replying. I'll try to find the other two VINs!
Here are some more views.
DuckRyder
Post by DuckRyder »
“J” is also the color code for Grabber Blue, which would have been one of the special Explorer Special colors would it not?
Truck looks like it could have been grabber blue.
OOPS, sorry looks like hdman covered it.
hdman90
Post by hdman90 »
Actually, now that you posted another view, it looks like that steering column is a 78-79 column. Maybe someone added a 78-79 tilt column? That is a common swap for people to do...
Mancar1
Post by Mancar1 »
Welcome aboard from Tehama County, ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Geographer
Mancar1 wrote:Welcome aboard from Tehama County, ca.
Mancar1, heave off and clear the fo'csle!
Rick
LHA-3
LPH-3
LPH-10
Huey Crew
HC-1
SeaKing and SuperStallion crew
VP-31
VP-40
CPWP
VP-47
VP-1
NWTS/VX-30
VP-9
per diem rat
Mancar1
Post by Mancar1 »
Rick
I hear ya loud and clear.
Fair winds and following seas.
John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
