A/C Compressor bracket for FE - New Design
Private parties only. No eBay/Craigslist listings.
tylerb43
Postby tylerb43 » Thu Nov 29, 2012 8:04 am
Hey guys, I've been asked by several, so I'm selling a bracket I designed to mount a modern A/C Compressor on my 390. (I never liked the look of the compressor and associated hoses on top, blocking the view of the engine! :) )
This bracket was designed to mount a modern, Sanden 508 style compressor on the passenger side of the engine, below the alternator. This should mount on all FE engines. Your compressor doesn't have to be a Sanden brand, as most modern compressors copy the Sanden 508 dimensions and mounting features. But if you're not using the Sanden 508, the confirmation of the fit is up to you.
Please notice that I'm using a 4-groove crank pulley, if you're using something different, you'll have to figure out your own spacers to make the pulley grooves line up. My front-most groove will be empty, meaning a 3-groove pulley should work, but I'm assuming here because I don't have one.
The bracket is cut with a waterjet out of 3/16" steel. This is a high quality cut with very precise edges.
325 326
327 328
329 330
The brackets are for sale two different ways:
DIY Version; You weld, grind and finish. $70 free shipping
Fully welded Version - $80, plus $13.60 shipping. (it fits in a medium USPS flat rate box.)
These brackets have been successfully installed on dozens of Bumps, Dents, Galaxies, and even a '62 Mercury Monterey!
Please ask any questions below, email, or PM me.
Just send an email to tylerblankenship@yahoo.com with your preference. (welded or unwelded), and I'll send you an invoice via paypal. I'll add tracking information to the paid invoice when it ships, easy as that!
Thanks!
Re: A/C Compressor bracket for FE - New Design
Postby Ranchero50 » Thu Nov 29, 2012 10:59 am
Tyler, great looking peice.
One question, do you have room for a diagonal brace for the rear mounts or somthing that would tie into the block back there? Seems that with everything hanging off that 3/8" plate you'll have a lot of flex with the belt tight, especially if your pulley is @3-4" away from the bracket (more leverage).
I just went through this with a Farmall H alternator conversion kit with a 3/8" mounting plate and it flexed horribly. With the belt barely tight it pulled the pullies out of alignment As a farmer fix I cut a 2x4 to cage between the bracket and the water pump to keep it from flexing.
Just trying to help your part succede,
Jamie
Builder of dreams, breaker of hearts. Play nice or go away.
tylerb43
Postby tylerb43 » Thu Nov 29, 2012 11:40 am
Jamie, thanks for your input. The rear mounts of the compressor are secured by the welded "arm". This arm is meant to resist the axial moment loads introduced by compressor torque. Meaning that under load, the rotational axis of the compressor stays parallel to the axis of the crankshaft.
Here's another look at a mock-up installation: Please note the spacers cut and installed over the bolts. This is important so you're "pinching" the mounting ears, not pulling them together. With the alternator installed and all the bolts torqued, this assembly is quite rigid. I guess I could sell it with all the spacers cut, but I figured you guys could save a little of my time and your money by covering that part yourselves. (I cut 3/8 iron pipe to length) :thup:
44Bulldog
Postby 44Bulldog » Fri Nov 30, 2012 11:11 am
Sent PM.....
I would like to purchase the welded / unfinished model.......
Let me know
tylerb43
Postby tylerb43 » Fri Nov 30, 2012 6:12 pm
44Bulldog wrote:Sent PM.....
Let me know
Thanks 44Bulldog! PM replied.
mrollings53
Postby mrollings53 » Sun Dec 02, 2012 3:42 am
A couple of questions:
Does it share any belts with the alternator or power steering pump?
What size are the belts?
Is the spacer behind the alternator lower bolt still used? Is it the original size?
Is that an OE water pump or an aftermarket one? I ask because my milodon pump isn't lining up with my '74 alt/AC idler bracket.
Will any version of the upper alternator bracket work or just the one used? Mine has a joggle near the end that is attached to the water pump, shifting the alternator forward.
Does the lower bolt on the compressor go through both bosses or just the front one?
Is that compressor adaptable to the original A/C components (e.g. connections, hoses, refrigerant)? What is required to make it work, or a good source for this info?
Where do you get a four groove crank pulley?
Whats the part number for the alternator? It's mounting bolt distance seems like it is short compared to a stock 3G. Or, is modifying the upper bracket not necessary with this setup? (The stock factory air setup has the alternator hanging down; requiring the bracket to be lengthened.)
I think that's it for now. It's a good looking part. I would be very interested in this setup.
Common Sense is an Uncommon Virtue
tybob81
Postby tybob81 » Sun Dec 02, 2012 4:44 am
If this was Facebook I could just "like" this post, but since we don't have that function I must say that is a slick setup! Hope you sell a ton of them because it looks like a high quality piece.
1968 swb hydroboost w/4 wheel discs, ididit tilt column, p/s, all led lights, Vintage Air and painless wiring. F.A.S.T ez efi 5.0, Built AOD. Addco front & rear sway bars, Custom wood bed floor. Full frame off resto-mod.
1968 Crew cab shorty 393w, M5R2, Vintage Air, 4 link and cv front suspension, hydroboost w/ 4 wheel disc brakes...under construction.
44Bulldog
Postby 44Bulldog » Sun Dec 02, 2012 11:10 am
Thanks for the quick response.....
PM sent with Pay Pal info....
tylerb43
Postby tylerb43 » Sun Dec 02, 2012 3:00 pm
mrollings53 wrote:A couple of questions:
No, mine doesn't. It has it's own belt off the crank pulley.
There's quit a bit of adjustability, so you could easily measure and go to napa. I'll try to find the part number I came up with.
Yes, but it's shortened to compensate for the new bracket thickness.
I have an OE water pump. This bracket replaces the original lower alternator bracket, and uses the same 2 bolt holes on the water pump.
I haven't tried any other version of upper alternator bracket. I have several FE engines, and they're all identical to what's shown.
Just the front one.
I guess I'd have to say Google is your best resource for researching a/c systems. My compressor uses R134a and applicable hoses and fittings.
I don't think you'll need a 4V pulley, as I said I'm only using 3 of my 4 grooves. I know CVF racing sells a 3V pulley if you can't find a Ford one.
My alternator is a 130 Amp model, Ford 3G off of a '97 Taurus. It has been rebuilt and fitted with a V pulley. It's 7.0" between mounting bolts. My upper bracket is stock '69.
And that's more than a couple questions, bud. :D I hope I helped. :thup:
mrollings53
Postby mrollings53 » Mon Dec 03, 2012 2:32 am
Thanks for the replies. I've got another question for you. Are you running a PCV on the driver side valve cover? And, do you have power brakes? Because, your valve covers don't mix well with the stock brake booster. My covers are positioned the same, and I'm still trying to figure out what to do for a breather with a built in valve that doesn't hit the edge of the booster. Or, if you have power brakes and already figured out what fits; what did you use?
abyars111
Postby abyars111 » Fri Aug 30, 2013 11:33 am
Tyler, are you still making these brakets. Slick set up.
Has anyone installed one?
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
tylerb43
Re: A/C Compressor bracket for FE - 11/25/13 Improved Design
Postby tylerb43 » Mon Nov 25, 2013 9:02 am
Hey guys,
I've made a design improvement to the bracket I thought you may be interested in. The rear mount now extends down and around the compressor body to pick up another mounting ear. And I designed a "X" connector between the front and rear mount. This makes a substantial improvement to the rigidity of the mount and addresses some inputs made by respected forum members. As previously design, these are water-jet cut out of 3/16" steel plate.
See below a few pictures on the bench and a couple mock installed on my motor. The bracket in the pictures isn't welded yet, it just fits together that tight.
Now obviously, I designed and made this for my engine, but I figured I'd offer it up to my fellow Fordification members in case they're struggling with the same challenge I was facing. I'll sell the bracket in the "you-weld-it" state only for $65, including shipping to the lower 48 states.
Thanks guys! :fr:
1972hiboy
Postby 1972hiboy » Mon Nov 25, 2013 2:38 pm
thats sweet looking. Are you offering a complete ready to bolt on option as well?
Rich
1972 f250 ranger XLT Camper Special 390
Dont eat yellow snow.....
abyars111
Postby abyars111 » Fri Jan 30, 2015 5:54 pm
Tyler, are you still selling these brackets either welded or not welded? I'd like to have one when I switch to the Sanden compressor.
Anthony
tylerb43
Postby tylerb43 » Tue Feb 03, 2015 7:01 am
abyars111 wrote:Tyler, are you still selling these brackets either welded or not welded? I'd like to have one when I switch to the Sanden compressor.
Hey Anthony! Yes, I can still have these cut and shipped to you in the "you-weld-it" state. PM me if you'd like one. :thup:
Return to “Parts for Sale/Trade”
Who is online
