1967 F 350 Cab Shell
Private parties only. No eBay/Craigslist listings.
Petewrench
Post by Petewrench »
1967 F 350 Cab shell. it's starting to get a little ragged along the back of the cab, and in the corners by the "A" pillars, Found a few tiny holes on the outside cowl panel (usual places that they start), but overall, this is a good solid cab. Everything has been removed. I will also include the outboard frame pads ( you will need them if you are putting it on an F 100 frame)
$450
I'm looking for the following parts for possible trade
SB Frame Mounts,
SB Manual Bell Housing
Power Steering Box
SB Springs, and disc brake knuckles
All that fit F100
Regards,
Pete
"WARNING! Being Hit with The "Brick Of Life", is just a hint that you are about to be run over by the "Boulder Of Being"!"
:bdh: :hn: :rant: :wf: :drive:
1967 F-100 Base Long bed. 390 4Bbl, NP435 4Spd, Manual Steering, Manual Brakes, A/C. (BlueBeast).FOR SALE-NOT!
1967 F-350 C&C, 159"WB.(Donor Truck)
1967 Mercury Cougar Standard. 5.0 HO, RUG-E 4 Speed, Factory Triple Black, Console Car.(SOLD)
63Galaxie
Re: 1967 F 350 Cab Shell
Post by 63Galaxie »
Got a bell housing for you, I'm looking for a F350 front drum hub if you got one I'll trade you.
Petewrench
PM Sent
