Brake Prop valve upgrade
Zorm
Post by Zorm »
Found one of these off a 77 that is mounted in the same place as the smaller valve thing I have for the front brakes so now I'm in search of some hard brake lines for a 77 F250 with the proportioning valve mounted on the engine cross member. I need the ones from the master cylinder to the valve and from the valve to the front brakes.
If any of you have any of the 73-79 f250s, would you mind looking? they are getting few and far between in the local junk yards.
thanks
