air tank volume
big orange
Re: air tank volume
Post by big orange »
mrsnicks wrote:Semi-related.... Has anyone thought about, or actually added a 2nd tank to their air compressor?
I found this on craigslist
And was wondering how it would work adding it to my existing 60 gallon air compressor/tank setup.
Patrick
I was also wondering the same thing. Even though my compressor can handle ANYTHING i was wanting to put an extra tank on it for more capacity :hmm: I have an Ingersoll Rand type 30, 2 stage, 8 Hp, 100% duty cycle Think its 80Gal :?
I cut it twice and its still too short!!
Re: air tank volume
does tank size have to do with gallons? my 22 gallon is a larger tank than that.
big orange
Re: air tank volume
fordman wrote:does tank size have to do with gallons? my 22 gallon is a larger tank than that.
My tank measures 20"x63".. it just looks small in the picture :thup:
oldschoolrods
Re: air tank volume
Post by oldschoolrods »
the only thing you'll gain with an extra tank is longer time between cycles, but then the trade off is longer run time when it does run, if you have an 80 gallon I'd say your probably good to go :thup:
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
OldRedFord
Re: air tank volume
Post by OldRedFord »
The air compressor I have is a 80 gallon one, tank is plenty big for home use.
It lasts a good while using air ratchets and impacts, and keeps up nicely with my sandblaster.
My old old comepressor was a 30 gallon (IIRC) Craftsman portable, definate performance improvement with a bigger tank and a pump with more CFM.
Never did trust those "oil free" pumps anyway.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
