Parts washer upgrade
Busboy
Postby Busboy » Thu Jan 21, 2016 8:13 pm
I have made an amazing improvement on my Harbor Freight parts washer. I bought a closeout water heater element at Home Depot for 5.00. It is rated at 1500 watts and operates on 110 volts. I drilled a hole in the side of the tank and installed the heater element with its O-ring and locknut on the inside. It absolutely doesn't leak and the results are amazing! I use a water based heavy duty degreaser from Home Depot. It was only about 10.00 for a gallon. This combination of heat and degreaser will take the paint off of oil pans easily. It gets so hot that after an hour I have to turn it off because the steam is so great. It takes about an hour to heat up to full temp. :D :D :D
1969 F-250 Camper Special, custom cab.
1967 F-100 4x4 custom cab.
2016 F-150 Eco-Boost 3.7 liter. (It will smoke the tires!)
Wilfred of Ivanhoe
Re: Parts washer upgrade
Postby Wilfred of Ivanhoe » Mon Feb 01, 2016 5:17 pm
Wait, it will take the paint off?! as in a home made blaster alternative? :evil:
1969 F100 LWB Parts truck
KRob
Postby KRob » Sun Oct 16, 2016 2:48 pm
Yeah, please confirm that it takes paint off and so forth.
Can you give us a link for the degreaser you use.
71 F250 4x4, 4BT Cummins Still in Project Phase...Project Thread http://www.fordification.com/forum/viewtopic.php?f=22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
Busboy
Postby Busboy » Sun Oct 16, 2016 8:30 pm
I used Purple Power.
48prerunner
Postby 48prerunner » Wed Nov 02, 2016 4:25 pm
Do you have to wear rubber gloves?
Return to “Garage/Workshop & Tools”
Who is online
