gas tank vendor opinion
Tell us your good and/or bad experiences
kevins72
Post by kevins72 »
Hello, im going to order a new in cab gas tank and sending unit for my 72 f100 ranger. Has anyone ordered a good one from a vendor you would recommend? Want to order as soon as i can get some good feedback. I will post my experience after install... thank you, kevin :fr:
rsjoons
Re: gas tank vendor opinion
Post by rsjoons »
LMC....cheap, fast and bolted right up on my 71 F100.
kevins72
Post by kevins72 »
Thank you for your recommendation, i did order from LMC and your right it bolted right up and works good, ive only went for one 20 min ride so far, seems good. I did not like that there was no packing in the box to protect it and i had to straighten most corners, i also ordered a sending unit, you would think by ordering both pieces, one of them would have come with screws for the sending unit, but they did not. Also i ordered the filler neck and non-locking gas cap, but the cap does not fit the neck. I called them they think the cap should fit the neck, they are going to check on it and call me back. We will see! Thank you again. Kevin.
