my green 68
cole71
Re: my green 68
Post by cole71 »
I was wondering what kind of shorty headers you used? How was the fit? I have a 302 I'm trying to decide which shorty headers to use.
tybob81
Re: my green 68
Post by tybob81 »
Fox body style fit fine.
cole71
Re: my green 68
Post by cole71 »
Ok thanks.
tybob81
Re: my green 68
Post by tybob81 »
Test fitting the intakes. Still have to bead blast my upper and lower.
72bumbee
Re: my green 68
Post by 72bumbee »
Wonderful truck!
Thanks for sharing!
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
tybob81
Re: my green 68
Post by tybob81 »
Starting to get it put back together. Gt40 3 bar head swap done along with bolting down my 1.72 roller rockers and edelbrock performer 5.0 lower, 24# injectors and explorer fuel rail. The upper has a 70mm tb.
I modified a stock fox body 5.0 throttle cable bracket to work with my lokar tv cable and bought a universal lokar throttle cable to match the tv cable. Im either going to use a lokar pedal or a modified stock pedal I made.
Have to finish hiding and routing my wires for the MSD digital 6al box and efi harness.
Re: my green 68
SWEEEEEEET!
tylerb43
Re: my green 68
Post by tylerb43 »
Wow, that's a pretty motor buddy! Love the blue lower, what color are you doing on the upper?
tybob81
Re: my green 68
Post by tybob81 »
The upper is a bright silver like it was new from Edlebrock.
tybob81
Re: my green 68
Post by tybob81 »
Still waiting on my plenum spacer to come in. The valve covers I'm running are a little taller than stock and my throttle cable bracket touches the passenger cover. I should have the fast efi covered in powerbraid tomorrow. Still need a adjustable fuel pressure regulator since my rails use a 94 and up style mustang (2 bolt) regulator and all I have is a fix style (3 bolt)
tybob81
Re: my green 68
Post by tybob81 »
Getting there. Hope to have it up and running again before Christmas.
Broncobilly66
Re: my green 68
Post by Broncobilly66 »
tybob81 wrote:[i. Still need a adjustable fuel pressure regulator since my rails use a 94 and up style mustang (2 bolt) regulator and all I have is a fix style (3 bolt)
I got a 2 bolt adjustable reg. from Orielly auto for about $40. Seems like it was an 5.0 Explorer application
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
tybob81
Re: my green 68
Post by tybob81 »
Yes the factory one on it was adjustable, but only 30-40 psi. Fast efi system neefs 43 psi.
Broncobilly66
Re: my green 68
tybob81 wrote:Yes the factory one on it was adjustable, but only 30-40 psi. Fast efi system neefs 43 psi.
Sorry. I missed that detail :D
Just curious. Why are you running FAST over the factory setup? I put the factory MAF setup on the 351w in my 66 bronco, and am very happy with it. Sorry for the derail. Just curious
'66 bronco
'68 bronco
tybob81
Re: my green 68
Post by tybob81 »
The fast efi is tunable. I have ran factory harness and computers before in efi swaps and they are fine but not as crisp and they don't handle mods as well as the aftermarket does. I keep wanting to put my 393w back in or a 501 lima I have in my shop.
