my green 68
cole71
Re: my green 68
Post by cole71 »
Ok nice.
48prerunner
Re: my green 68
Post by 48prerunner »
Wow don't know how I missed this build, stumbled on it from a link over on ford truck forum on the sunpro gauge swap . Just read through the whole thing, Great truck really liked your idea for the wooden bed floor, did you go with a mustang tank? how is filling up in the bed?
tybob81
Re: my green 68
Post by tybob81 »
I'm running a Tanks Inc tank because I wanted to run a in tank fuel pump. I fill the tank through a billet fuel door in the bed floor.
48prerunner
Re: my green 68
What did you end up doing with your ac vents? Any pics? I know you mentioned about two in a center console. I've read the ct article a couple times like how you mounted your switches.
tybob81
Re: my green 68
Post by tybob81 »
Finished the hydro boost setup.
Re: my green 68
Very nice!
tylerb43
Re: my green 68
Post by tylerb43 »
That looks great, bud! Are you happy with it? How's does the system perform?
Where can I get those cool braided, bolt thru lines for the MC? I think I like those better than the standard looped hardline.
:thup:
tybob81
Re: my green 68
Post by tybob81 »
The brakes will throw you into the steering wheel if you don't watch it. I have not had much time to test it to much due to all this snow and junk weather this month. The braided lines and fittings came from Speedway. I used them because my stock lines didn't look good after bending them out to fit the new setup.
marvin2
Re: my green 68
Post by marvin2 »
Tybob, I'm reading through some of the bronco hydroboost write ups, but I do not see anything mentioning modifying the BC Bronco mounting plate. What did you do to the plate / why was it needed?...or am I reading your post wrong?
Thanks!
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
tybob81
Re: my green 68
Post by tybob81 »
I liked the way the BC bronco mounted , but the 67-77 bronco has a different firewall mounting holes so I cut it down and drilled holes. I like to research on the net, but then do it in a way that no one has done.
marvin2
Re: my green 68
Post by marvin2 »
Ok, got it. If I didn't want to modify the bracket, would it be possible to just drill matching holes in the firewall?
tybob81
Re: my green 68
Post by tybob81 »
If you want to.
tybob81
Re: my green 68
Post by tybob81 »
Got bored with my gauges so I went with a set of Stewart Warner Wing series.
I also bought a vinyl firewall pad to cut up to fit my truck. Needs something since I changed my gas pedal due to the efi swap and all the wiring and such.
waylon
Re: my green 68
Post by waylon »
marvin2 wrote:Tybob, I'm reading through some of the bronco hydroboost write ups, but I do not see anything mentioning modifying the BC Bronco mounting plate. What did you do to the plate / why was it needed?...or am I reading your post wrong?
Thanks!
I think the plates are mainly to stiffen the firewall. if you dont want to spend the money on the bcbroncos setup you could check out this
http://www.locofomocoracing.com/page2.html
Liam is a great can and can help you out. and his bracket set up is cheap. I have one on my shop shelf now and can check it on my 70 truck if you want me to
Waylon
marvin2
Re: my green 68
Post by marvin2 »
Thanks!
Waylon
That would be great Waylon...I'd be curious to know. Thanks!
