by tybob81 on Sat May 05, 2012 5:01 pm
I measured from the bottom of the front bumper to the ground and it is 12 1/2" and the center of the rear wheel well to the ground is 26 1/2". My tire size is 255/35/20 in front and 265/50/20 in back. It tucks all the rear tire in the wheel house. No c notch and it doesn't bottom out on the frame in the rear. I put around 500lbs (393 short block and 3" exhaust kit for my crew) in the bed when I was moving and it didn't bottom out bouncing down the side streets on the way to the new house.
1968 swb hydroboost w/4 wheel discs, ididit tilt column, p/s, all led lights, Vintage Air and painless wiring. F.A.S.T ez efi 5.0, Built AOD. Addco front & rear sway bars, Custom wood bed floor. Full frame off resto-mod.
1968 Crew cab shorty 393w, M5R2, Vintage Air, 4 link and cv front suspension, hydroboost w/ 4 wheel disc brakes...under construction.
