Bumps At Work!
71 LONG BED
Re: Bumps At Work!
Post by 71 LONG BED »
FLATBEDFORD wrote:bttmline, Either that's some very lite-weight dirt, or your truck has some pretty stout springs.
:lol: I was thinking the same thing!
John Member #1549
Image Image Image
thebttmline
Re: Bumps At Work!
Post by thebttmline »
Yep - that's mushroom compost - a lot lighter than dirt! :)
There is a mushroom factory about 15 miles from the house. They make compost, grow one crop of mushrooms, and then sell the spent compost. There is a conveyor belt coming out of the factory. You just pull up under it and let your truck fill up. It is great stuff for the yard / garden.
Still, it is a decent size load. I had a 1966 1/2 ton shortbed and it was really border line on being too much weight getting a full load. But the 3/4 ton long bed handles it with ease - even with those side boards. The highboy is a heckuva a lot nicer for hauling stuff!
Steve
1971 Ford F-250 4x4 Highboy - Pics
2003 Toyota Tacoma 4x4
rjewkes
Re: Bumps At Work!
Post by rjewkes »
kool, is it the kent or kenet mushroom place? i know when I worked at J-M in miami(Miam-Uh)ok, we had containers from them. The more i think they might be the one in pennsylvania.
fuelly.com
thebttmline
Re: Bumps At Work!
This one is Monterey Mushroom. Factory is in Loudon, TN. That mushroom compost is great stuff! :thup:
Steve
rjewkes
Re: Bumps At Work!
Post by rjewkes »
oh good old old montery i used to package for them around the holidays out of J-M Farms. always assumed they was from monterey, cauliflower.
fuelly.com
FordTruck
Re: Bumps At Work!
Post by FordTruck »
Here's my 70 F100 dragging the 72 CS around
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
1971ford
Re: Bumps At Work!
Post by 1971ford »
long story :( but heres my 71 working. trying to pull over the bronco, it failed. not enough wait in the rear even with the cell and the worn tires. it tried its very best though :D but what do you expect from it on a dirt road trying to pull a heavy bronco over onto its wheels. that deed requires 4x4.
-Ryan
FLATBEDFORD
Re: Bumps At Work!
Post by FLATBEDFORD »
1971ford wrote:long story :( but heres my 71 working. trying to pull over the bronco, it failed. not enough wait in the rear even with the cell and the worn tires. it tried its very best though :D but what do you expect from it on a dirt road trying to pull a heavy bronco over onto its wheels. that deed requires 4x4.
I bet if your tow rope had been about 2 or 3 times longer you could have done it. That close to the Bronco, it looks like the pull was taking the weight off your rear wheels. :2cents:
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
killakobra
Re: Bumps At Work!
Post by killakobra »
could have tried it in reverse, that way it would pick up the front end and put the weight all on the back tires
1967 f100 stepside 300ci I6
1972 longbed trailer
rjewkes
Re: Bumps At Work!
Post by rjewkes »
Is that your new bronco?
yeah What Flatbed said. Longer rope and a slight runnig tug. but be carefull too much tug and you'll have to do it again from the other side. I beleive that type of recovery out here would run 35 unless it was an accident between two cars and then it would be the police impound fee of 90.
fuelly.com
1971ford
Re: Bumps At Work!
Post by 1971ford »
yep i definately see how a longer tow strap would of helped! It definately seems that when the bronco started to tip up then the tow strap angle would increase even more and pull the wheels right up.
I did give it a few jerks. not big ones by any means because we had it around my axle! (and big jerks are dangerous/parts breaking anyways) but by giving it jerks it lifted the bronco maybe 6 inches from the ground then my tires slipped.
-Ryan
papabug71
Re: Bumps At Work!
Post by papabug71 »
1971ford wrote:yep i definately see how a longer tow strap would of helped! It definately seems that when the bronco started to tip up then the tow strap angle would increase even more and pull the wheels right up.
Oh no Ryan, not the axle!
Dont worry, I once watched a guy wrap a chain around the inside of his dual & pull his Dodge 1 ton out of a ditch. He tied it off to a tree. Then just slowly backed the truck out. As the duals turn, the chain pulls tight & pulls the truck out. It worked, but I was sure something was going to break.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
1971ford
Re: Bumps At Work!
Post by 1971ford »
i know i know, and i knew someone would question my stupidness on it but i know it wasn't the smartest thing :D Just remember i barely tugged on the bronco with my truck because of it. There was no where else to put the strap (cut out the frame crossmember and replaced with tube fuel cell crossmembers but didnt want to break those off) and no rear bumper.
-Ryan
papabug71
Re: Bumps At Work!
Post by papabug71 »
I must say, I have done it many times in the past.... :thup:
Matt
Mine since 5/7/'94
GSequoia
Re: Bumps At Work!
Post by GSequoia »
Two cubic yards of topsoil (If an estimation I read is correct that'll be about three tons) in a '71 F250CS with a 6900lb GVW .
Before
After
You can feel it when trying to take off but man I love every minute of those big Camper Special brakes!
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
