67 4x4
kenaikid123
67 4x4
Post by kenaikid123 »
New to posting but thought I would share my project I started in May.
Lone Ranger
Re: 67 4x4
Post by Lone Ranger »
That's looking awesome. Looks like your going boxwood green? I just shot my 69 highboy in boxwood I love that color. Your truck looks like you could eat off it
Kyle
popeyes71
Re: 67 4x4
Post by popeyes71 »
Looking good! Do you have any more detailed pics and brief description of what you have done? Looks like its going to be a killer truck when your finished!
-Popeye-
1971 F-250 4x4 Highboy
Cuda883
Re: 67 4x4
Post by Cuda883 »
Wow that thing is clean! Keep the pics coming. Love the 67!
67 F100 352 Lunar Green
kenaikid123
Re: 67 4x4
Thanks for positive comments. Having a hard time making pictures small enough to post. Will try some more later. Here is what I have thus far..
67 4x4 frame, 77 Dana 60/44 axles and power brake booster, 4wd steering column, 68 2wd front clip cab box, 73 429, 67 np435, 67 Dana 24, 78 power steering box, 1g one wire alt, edelbrock e street 2 EFI, serpentine belt kit, Saginaw PS pump, champion 3 row alum radiator.
Going to Painting it the color of firewall..Ford green gem metallic.
Thanks..Kris
kenaikid123
Re: 67 4x4
kenaikid123
Re: 67 4x4
kenaikid123
Re: 67 4x4
kenaikid123
Re: 67 4x4
lennyp
Re: 67 4x4
Post by lennyp »
Looks great.
lennyp
Re: 67 4x4
Post by lennyp »
Looks great.
daveford72
Re: 67 4x4
Post by daveford72 »
That almost looks like a factory build EXCEPT for that big block :D Great job!
SeapineF37
Re: 67 4x4
Post by SeapineF37 »
yeah killer project! start a thread over in the project updates section so its easy for everyone to follow along as she come together :thup:
PACrewCab
Re: 67 4x4
Post by PACrewCab »
Those tires on the steel wheels is a great look. I always liked that combo.
www.oldfordcrewcabs.com
1970 F250 Camper Special
1962 F250 factory 4x4
1996 F350 CC LB Powerstroke
popeyes71
Re: 67 4x4
Post by popeyes71 »
Great progress, I like how it is turning out! I have the same motor in my Highboy. I'm not sure if you have figured it out but with the exhaust manifold you have on the right side, it will be a tight fit for the exhaust system, unless you notch the frame. I'm actually swapping out the similar right side manifold to a different style that exits more out the back instead of down at the frame. I found the manifold on the newer Ford trucks that have 460's. If you have any questions about the swap, feel free to ask. I found it hard to get info on some of the little things like radiator hoses, belts, throttle linkage and fan shroud. Keep up the great work! By the way, what size are your tires?
-Popeye-
