What did you do to YOUR bump today?
No tech discussion, please
HIO Silver
Re: What did you do to YOUR bump today?
Post by HIO Silver »
68FORDJBM wrote:put on an aftermarket horn after screaming at stupid drivers for the last 5 years. It still doesn't work:(. I think it's the push button switch since the horn does work if you jump the wires at the relay.
This post has really taken off!
There is a little copper tang on the inside of the rag joint that bridges the horn pad/bar (a ground signal). Install a jumper wire across the rag joint and test your horn again.
And what did I do to my Bump? Well, I backed off the static timing from 12° to 6° BTDC because it was bucking when I get flat-footed. Reset the EFI idle speed, and it's running great with no hesitation. Cleaned the battery posts and terminals with baking soda and water. Applied petroleum jelly judiciously.... I'll switch to an AGM one of these days.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
spacecadet
Post by spacecadet »
shortened my exhaust to become side exit just before the rear fenders. Plus lots of other welding touch ups while the exhaust was out.
Im loving the deep rumble.
1968 F250 / 360 / C6
Wilfred of Ivanhoe
Post by Wilfred of Ivanhoe »
Bought parts. Fuel filter, ignition switch, tools, and other stuff I'm forgetting.
1969 F100 LWB Parts truck
arkrider410
Post by arkrider410 »
:fr:
low and ugly 72 longbed with a 360 converted to a 401 with performer intake and a 750 double pumper carb 260 cam and headers with a c6 auto and stock 9 inch lowered about 5.5 /7.
Build thread http://www.fordification.com/forum/view ... 22&t=79488
rwilly
Post by rwilly »
Put on new master/wheel cylinder and shoes.
Took it out for a short drive. It still needs work, but first
Thing I want is the proper throttle return spring.
AZf100
Post by AZf100 »
Installed my new tail gate with all new hardware as well. I Was surprised on how easy it is to open and close now..I don't know if it was money well spent but I'm impressed with the ease of operation.
"I ain't as good as I once was But I'm as good once as I ever was"
http://i1364.photobucket.com/albums/r73 ... 6e738a.jpg
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
spacecadet
Earlier this week, paid a shop to replace my oil pan(badly needed) and motor mounts(also badly needed).
Just haven't had time to deal with lifting or pulling the engine. I had all the parts so labor wasn't bad.
Today, replaced the valve cover gaskets with rubber ones and did some lite body work.
The oil pan was seeping all the way around and the PO had destroyed the drain threads and glued the plug back in- guess he never intended to change the oil again... The drivers side valve cover was also leaky. No more oil drops on the ground now :D
carnuck
Post by carnuck »
Dropped a load of metal to the scrap yard. Need to do it again, but loads are too small with the LPG tank in the bed. Decided to post it for sale. $1,000 without the propane system. I have the carb and electric fuel pump but no tank yet. Includes the 6 x 9' flatbed deck i have. Available in a couple weeks (I'm moving)
daveford72
Post by daveford72 »
Went to work yesterday morn in my 80 xcab 250 4wd noticed my dash lites were getting dimmer as I went. Got there and battery was dead. Same thing happened to my 67 f250 tow truck 2 months ago.The alternator was bad on the 67 I was picking up new one last nite after work.My 80 the belt was loose, Tightened up alternator and it started right up without No charge. Good battery just loose belt :D need my tow truck ready I bought a 79 250 4wd for $500 needs towed home :thup:
Russell J
Post by Russell J »
Been wanting to do this for some time now... :D
3 Speed
Post by 3 Speed »
Got it back from my mechanic, with new brake job (master cylinder, lines, shoes), re-packed wheel bearings, timing adjusted, new points, new condenser. Purrs like a kitten (well, a kitten with an exhaust leak...).
Washed it, tried not to look at the surface rust.
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
spacecadet
Finally got around to machining my aluminum air cleaner knob. As the tuner kids say, straight billet yo 8)
ok68crewcab
Post by ok68crewcab »
Put on new wiper blades. Just the basic Trico blades from O'Reilly's.
2 Blessed 2 Be Stressed
flyboy2610
Post by flyboy2610 »
I like the Duralast winter blades from AutoZone. They are the ones with the rubber covering on the frames. I've been quite happy with them.
http://www.autozone.com/ignition-tune-u ... ckfit=true
Red Green
you'd better be right.
Bosch blades are about the best I've found that don't decompose and streak after four months, just saying.
Per the truck, it's been getting used as a truck and mobile work bench as the oldest son and I install some privacy fence around the property. Going to haul some goat food and a bunch of scrap metal to a friends today. Spring cleanup, yay.
