Need help with a VIN number...
No tech discussion, please
1970 SportCustom
Post by 1970 SportCustom »
Hello everyone. I am a new member and not sure if I am posting this in the right place or not but I'll give it a try.
So here's the story: I picked up a 1970 f100 Sport Custom last week and the vin is F10GCJ85994 which (as I'm sure you know) means that the truck was built in Aug 1970. The truck has a '71 grill and power disk brakes which I have been told are factory.
Is this truck a true 1970 since that is what the vin says or would it be considered a 1971 since it was built so late in the year and has the options listed above????
Thanks for any help you can give!
DuckRyder
Re: Need help with a VIN number...
Post by DuckRyder »
Based on http://www.fordification.com/tech/VIN71.htm it seems entirely possible it is actually a 1971.
I don't think it is possible that the power disc are factory though...
69Ford
Post by 69Ford »
This is what your VIN says
F10GCJ85994
F100
302 cid V8
Ontario Canada
Aug 1970
1971 Model Year
I believe it is a 71 Is the steering wheel Three small spoke's 1970, or two larger more modern spokes 1971. This will be a way to tell. Here's a pic of the 1970 wheel.
1970 SportCustom
This really clears things up. Thanks everyone!!!
69Ford
Post by 69Ford »
1970 SportCustom wrote:This really clears things up. Thanks everyone!!!
So what did you come up with 70 or 71
1970 SportCustom
I'm going with 71
1970 SportCustom
I tried to post a few pictures but it keeps telling me that the files are too large.
ok68crewcab
Post by ok68crewcab »
You can also double check the VIN that is stamped on the frame to see if they match in case the door tag isn't the original.
2 Blessed 2 Be Stressed
1970 SportCustom
Where would it be located on the frame?
TNIceWolf
Post by TNIceWolf »
Presently in the stable
1969 Ford F-350 DRW
