VIN decode
VIN decode
Looking @ a '69 w/ a DSO of A47471. Per the Fordification on-line decoder; American orders used only numbers & Canadian orders started w/ B so the syntax doesn't fit the Fordification decoder. Any feedback? Thank you.
"If you're not liberal at 20, you have no heart... if you're not conservative by 30, you have no brain." Winston Spencer Churchill
- mk
Re: VIN decode
Your dso indicates a Lincoln/Mercury dealer order in probably Saskatchewan or Manitoba. 'A' was used for the Canadian Lincoln/Mercury dealers and 'B' was used by the cdn Ford dealers. The sales zones were numbered 1-7 across the country from the east. Therefore, a B6 would be an Alberta Ford dealer and A7 would be a BC L/M dealer. Prior to may '68, this A code would be a possible indicator of an original Mercury pickup but the only way to know for certain would be to get a Marti Report. After the spring of '68, both the cdn Ford and L/M dealerships sold only Ford trucks.
mike
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
~Will Rogers
