What options do CS models have the others don't.
No tech discussion, please
AlleyCat
Post by AlleyCat »
I've been reading posts for the last few days trying to figure out exactly what equipment came with a Camper Special package. My newly acquired 70 F250 has most of the CS stuff but it's not marked as one. Drive train is a 360, C6 with 3.73 gears. Factory p/s, p/b and a/c. The GVW on the rating plate is 7500. It has the dual diaphragm booster, dual piston front calipers and what appears to be the wider rear drums. It also has an auxiliary gas tank with a skid plate that looks factory and the side mounted tool box. There are no sway bars but I've seen other C/S's that didn't have them. I looked at the rear of the frame in search of any auxiliary power connections but the wiring there is a rat's nest of scotch locks and tape. Anything else I can look for? :)
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
Bill Ramsey
Re: What options do CS models have the others don't.
Post by Bill Ramsey »
there should be some relays behind the glove box that click when you turn on the headlights. those are for the camper wiring.Normal trucks dont have them. Also, normal trucks dont have Camper Special emblems so theres that.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1972hiboy
Post by 1972hiboy »
I believe there was supposed to be a flat plug under the bed somewhere for camper wiring too. :hmm:
Rich
Dont eat yellow snow.....
Bill Ramsey
1972hiboy wrote:I believe there was supposed to be a flat plug under the bed somewhere for camper wiring too. :hmm:
i believe this is correct, i will verify this weekend.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
