koch68 wrote:Do you have Pictures of cb location? And the rest of interior?
averagef250 wrote:Disregard if you already know this, but at some point around the 48RE intro Dodge went to a re-useable pan gasket. When you're bench building an auto there's a pretty good chance you're going to drop the pan a few times and that re-useable gasket is slick (and putting a drain in the pan). The gasket's around $15 and you only need to buy it once.
Also, be sure to follow the procedure for setting up the OD piston selective shim. It's in the ATSG book if you already have one. You can't just figure it will work because it worked before. The shim is dependant on the OD clutch stack height, change clutches, gotta change shim. There's a sonnex universal kit if you want to buy it in advance, but the solid shims are cheaper.
Nice work!
