My 72 Sport Custom F100 (Shes alive!) 10-21-2010
OldRedFord
Post by OldRedFord »
Pics of recent work I have done.
Rebuilt front passenger side brake and cleaned and painted the radius arm and I beam, coil spring, drum and backing plate etc. Then my brother decided he would pressure wash the driveway. :doh: :o
Pulled trim off passenger door to get a better look at the rust. I may replace the door instead of welding patch panels.
Cut out rusted area in cowl/firewall. Surprised at how solid the cowl is.
This is a view of the area from inside the cab, looking through the radio hole. The rust that you see goes out to the folded over lip on the firewall.
Think if I clean it up and paint with POR-15 Ill be ok?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
1971ford
Post by 1971ford »
sweet :rock: , id definetly replace that door.
inside that cowl doesnt look bad at all for a water highway.
your painting makes me want to go get a wheel off and start rebuilding the brake system :thup:
so are you redoing the complete braking system?
keep the updates coming!
and yes, por-15 will be fine just layed down right there :thup: id clean the surface really good though, keith always says that its all in the prep work :thup:
-Ryan
OldRedFord
Painted drivers side beam and arm.
Drivers side backing plate
Entire brake system is being gone through. New shoes and hardware and cylinders (front and back) new rubber brake lines (front and back) replace metal brake lines as needed, and replace front parking brake cable (its broken)
Tim
dcbullet
Post by dcbullet »
shiny!
1971ford
re: My 72 Sport Custom F100
Post by 1971ford »
man if i brought big truck parts inside my house, i would be living in my truck garage :doh:
:pop:
-Ryan
OldRedFord
Finished up the front brakes today. All that is left is to pick up the other shock I ordered. Also installed the engine mount towers for the 460.
http://smg.photobucket.com/albums/v237/ ... C02302.jpg
Shot of the towers and part of the painted steering linkage.
http://img.photobucket.com/albums/v237/ ... C02301.jpg
Drivers side
http://img.photobucket.com/albums/v237/ ... C02300.jpg
Passenger side
Tim
1971ford
Post by 1971ford »
sweet :thup: :thup:
shocks sure stand out and look awesome :thup:
-Ryan
H-DFord
Post by H-DFord »
Yes I agree. It really is looking good.
1968 Ford Ranger Lb
2007 Harley Electra Glide Classic
craftsman
Post by craftsman »
How does your engine mount on those towers? I don't see any holes in them.
All those parts looks good. :thup:
OldRedFord
The bolt holes are on the side like this :
http://www.fordification.com/images/FAQ ... s_left.jpg
Tim
craftsman
Post by craftsman »
Ok, i haven't seen them before, must be 460 mounts. Thanks.
Keep us informed. :thup:
OldRedFord
Sorry I haven't been on here in a while to update this, been busy with work and women problems lol.
So the front end is back on the ground now.
Ordered and received new pre bent steel brake lines and all new parking brake cables from NPD.
Then pulled the rear end out. Then realized I need one new brake drum, decided to replace bolth. None of the parts stores here seem to have them so I Ordered 2 from LMC Truck. Also Ordered some POR-15, (six pack) Marine Clean, and Metal prep.
Also bought a new rubber brake line for the rear end and a new master cylinder. Getting funds up for a new brake booster and new rear shocks.
Went to install the pre bent brake lines from NPD. Everything seems to fit cept the 2 front lines. The ones that go to the drivers side and passenger side drums. They are bolth too short.
But what I Ordered is for a 72 F100 2 wheel drive with power drums....so Idk whats up, will be calling customer service as soon as I get a chance.
Will be posting up pictures Sunday.
Hopefully Ill have the rear end back in, and the parking brake cables installed by Monday night.
Then I need to find a drive shaft, radiator, and shift linkage, and a x member and start ordering parts for the 460 8)
Tim
OldRedFord
Crusty old 9" out of the truck.
POR-15'd brake drums for the rear.
Painted up leaf spring and new master cylinder.
Another angle.
I also picked up this stuff calld Jasco Prep & Primer and a cleaner calld Purple Power at Lowe's yesterday. Im allready almost out of my quart of Metal Ready and the Jasco claims to do the same thing. The Purple Power claims to be pretty potent, and I have heard that It will remove paint even, so Im going to test these products and report back.
If the Jasco stuff works, would be nice, dont have to pay for shipping and all.
Tim
rjewkes
Post by rjewkes »
on the lines the fronts stop just above the frame and go down to rubber lines, so you'll need them too.
fuelly.com
OldRedFord
rjewkes wrote:on the lines the fronts stop just above the frame and go down to rubber lines, so you'll need them too.
Already replaced those, the steel lines just aren't long enough to go from the rubber lines to the distribution block. :?
Used the Purple Power on the other leaf spring today, cleand it up pretty good. Seems comparable to Marine Clean.
Tim
