Big Red 69
Re: Big Red
Postby TNIceWolf on Fri Nov 05, 2010 7:15 pm
One of the possible upgrades I mentioned is a F-600 dash panel conversion. However I am a bit stuck as to how to best proceed in that .
My problem is that I may have arranged for the possibility of too many options......if that is possible.
Below you will find pics of some of the pieces I have lying around handy here for the upgrade and I am wondering which to use and what other bits I have lying around might best be adapted to work with them.
A pic of one panel
And a pic of the other
Any comments or suggestions? I see a few possibilities here if I look in my parts stash but am curious about ideas others may have as well.
Presently in the stable
1969 Ford F-350 DRW
My F-350 project viewtopic.php?f=22&t=41744
TNIceWolf
Re: Big Red
Postby 67bartcat on Fri Nov 05, 2010 8:51 pm
I vote for the Black one but the white one is cool too. :)
67bartcat
Re: Big Red
Postby 1971ford on Sat Nov 06, 2010 12:10 am
The black and chrome is nice but I'm guessing that its a little beaten up. if I was to get one of those panels it would have to be damn near perfect or else it would drive me crazy looking at a warn out chrome-pitted cluster. Therefore the white one looks very clean and is easy on the eyes...
-Ryan
1969 F250 4x4 - Frame-off rebuild, Cummins, built 518, Flatbed, 4" lift, 37" tires, and much more
Build Thread: viewtopic.php?f=22&t=26870&start=840
SOLD -1971 F100 Offroad Race Truck - 429C.I., ATO fully built c6, 22" wheel travel, Engine/cab/bed cage, 35's, hydraulic bump stops, coilovers, Alcan leaf springs
Build Thread: viewtopic.php?f=22&t=33697&st=0&sk=t&sd=a&start=615
1971ford
Re: Big Red
Postby killakobra on Sat Nov 06, 2010 3:08 am
that all depends on what look you want.  the white will give you a simple look. here is a pic of mine
the black would give the truck a cleaner look.
1967 f100 stepside 300ci I6
1972 longbed trailer
killakobra
Re: Big Red
Postby TNIceWolf on Mon Nov 08, 2010 6:15 pm
Thanks for the replies and input guys!
I am kind of leaning toward the black and chrome myself. I kind of like the way the gauge faces look a little better. Either way I go I am looking at some wiring work to make the ALT gauge function correctly seeing as how my present original cluster is not fully gauged. I also have handy a trio gauge aftermarket set I am planning on installing somewhere as a secondary backup system. The black cluster is made for allowing two switches to be mounted without disturbing any of my lower dash mounted switches. What I was thinking was to move the emergency flasher switch from the glovebox since I have a later type switch handy , and intall a blinker switch for the marker lights I also have handy. Since I have an aftermarket tach lying around I might as well go with that in the cluster as well.
The white one is a very clean piece to be sure. But the white just doesnt fit my style. I could use it with some repainting I am sure. I have an extra vacum gauge that could be put in it and all the other parts I mentioned would work as well. Since it has that third hole for controls of some sort that would leave me looking for something to fill it. I just aint crazy about blank out plugs in the cab.
It is going to be a springtime job anyway so I have plenty of time to think and plan.
I will try to get some pics up tomorrow night of the next major interior upgrade I am considering.
Keeps those comments coming! Food for thought is good for the soul.
1969 Ford F-350 DRW
TNIceWolf
Re: Big Red
Postby killakobra on Tue Nov 09, 2010 1:05 am
i'm not sure what year your truck is but if it's a 67 it should be a plug and play matter.  i have a 67 and a 72 f600 panel plugged right up.
killakobra
Re: Big Red
Postby FormerMarine1981 on Sun Nov 14, 2010 10:43 am
Nice work you have done on your truck. Look forward to further updates.  :thup:
Last edited by FormerMarine1981 on Thu May 17, 2012 9:25 am, edited 1 time in total.
What we do in Life, Echoes in Eternity
FormerMarine1981
Re: Big Red
Postby TNIceWolf on Sun Nov 14, 2010 1:45 pm
Here is a pic of the next area I want to upgrade. It is less than a 300 dollar install and should be a whole lot better than what I have at the moment.
1969 Ford F-350 DRW
TNIceWolf
Re: Big Red
Postby elgemcdlf on Mon Nov 15, 2010 1:33 pm
I have a suggestion. I came across a pic of a '65/'66 Custom Cab cluster. Has the 4 guages but the speedo is rectangular shaped. I am pulling the dash out of my '70 and replacing with a dash from a '61-'66 F100. I like the little rise above the cluster in the dash. I am then using the cluster from the '65/'66 Custom Cab. The factory tach is cool though. I heard they are cable driven so getting hooked up might be a problem.
elgemcdlf
Re: Big Red 69
Postby TNIceWolf on Thu Jan 13, 2011 12:19 pm
I think this might fit in the project well if highly polished and refurbished!
What do you guys think?
1969 Ford F-350 DRW
TNIceWolf
Re: Big Red 69
Postby Mancar1 on Thu Jan 13, 2011 1:09 pm
Yes that would look good. :thup:
2010 Escape XLT, V-6, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Mancar1
Re: Big Red 69
Postby TNIceWolf on Wed May 16, 2012 6:11 pm
Over a year now with no progress. Finally got the old girl out last week and got it legal again. Then it was off to the shower with her for a much needed bath. Been driving her around to work daily to loosen her up a bit and get her ready to go to a meet and greet of Fordification members this weekend in Sevierville and then onto the F100 Supernationals in Pigeon Forge. Been working on it during breaks and lunches at work and what little time I have at home. Finally got a few small things done. New starter relay.....ignition coil....and voltage regulator. Also added all new 2 Gauge battery and starter cables and retuned the carb. Still needs a ton of cleaning and some work on the lights but it should be ready to roll Saturday.
1969 Ford F-350 DRW
TNIceWolf
Re: Big Red 69
Postby TNIceWolf on Sat Jun 16, 2012 9:58 am
Got a little more done here lately. Replaced the headlight switch and dimmer switch.  Was having some trouble with having headlights one minuite and then none the next.  That should set the stage for some much needed work on the bed marker lights and the addition of the missing front fender marker light on the drivers side. We have run up on some unexpected down time at work and it seems possible that this year will see some changes on the old rig. No work means less money of course but makes for a good opportunity to thin the parts pile down a bit. Drove the old rig down to Spartanburg South Carolina last weekend to pick up some running boards and grab handles I purchased from another member on here. The old girl turned in a pretty good performance on the trip. So much so that Miss Yvonne and I decided to drive over to Asheville NC when I got back home from the parts run and tackle the Blue Ridge Parkway up to Boone for a nights layover and then a leisurely stroll back down the mountains to home again. If I can manage to get some of the parts I have lying around installed this summer I can start laying the groundwork for body repair and bed replacement. It has been a long haul just to get this far with it and looks like even longer to get it closer to what I want.
1969 Ford F-350 DRW
TNIceWolf
Re: Big Red 69
Postby sargentrs on Sat Jun 16, 2012 11:45 am
Great Charlie!  Yeah, but it's a labor of love, ain't it?  Good luck and post us some pics every now and then.
How come when your wife or kid's Japanese cars break down, it's always the beat up ol' Ford truck that comes to pick 'em up?
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding.
Stolen on March 2006 - recovered and returned May 2007. I am truly blessed.
Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
Re: Big Red 69
Postby FLATBEDFORD on Wed Aug 01, 2012 4:00 pm
I've been out of the loop for a while. How's the old 1 ton doing? I plan to get back into mine in the next few weeks. I have a borrowed MIG welder and I am teach myself how to do some sheet metal repair. Hopefully I will get notifications again when you post.
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18
2000 F250 XLT, 4x4, Supercab, V10, Auto
2006 Focus ZX3 SES 5spd
2006 Volvo S60 AWD (Mrs. FLATBEDFORD)
Driveway full of Ford (kinda)
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
FLATBEDFORD
PreviousNext
Return to Project Updates
