1967 F-100 project
67nukeford
1967 F-100 project
Post by 67nukeford »
Oops, posted this in the wrong forum, so I'll repost here. Anyway, after ten years of waiting, finally getting her tore down. Here are a couple of before pics..
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
67nukeford
Re: 1967 F-100 project
Sheet metal removal..
Pat 1967 F100 4WD
67nukeford
Here are some pics of the I-6 300 coming out. Will be replaced with a 390, and I hope a 80'ish 5 speed and transfer case.
Pat 1967 F100 4WD
67nukeford
Cab all cleaned out and ready to pull. I'm probably going to replace the cab with a 68 or later, I have access to one, and I like the updated heater controls. This cab would need both floorboards replaced and rockers if I used it.
Pat 1967 F100 4WD
67nukeford
Driver's side floor, even worse.
Pat 1967 F100 4WD
neverdone
Post by neverdone »
67nukeford wrote:Cab all cleaned out and ready to pull. I'm probably going to replace the cab with a 68 or later, I have access to one, and I like the updated heater controls. This cab would need both floorboards replaced and rockers if I used it.
any difference in a 67 cab?
neverdonekustoms
lunchboxxx
1986 bagged n body'd toyota...ls 6.0 project
1967 f100 2wd swb bag project
1983 720 datsun/nissan all original shop truck/daily
99 mountaineer donor for the 67
67nukeford
No, the only difference is with the dash. Othwewise, I'm told they are virtually the same. I like the sliding heater controls on the 68 and up trucks, mine has just the pull knob controls in the 67. And I'm also thinking of putting in AC, so I'll need the newer setup.
Pat 1967 F100 4WD
neverdone
Post by neverdone »
o gotcha....learn something everyday..good luck with the build
neverdonekustoms
lunchboxxx
67nukeford
Body is now off, thanks to my brother-in-law and his tractor.
Pat 1967 F100 4WD
67nukeford
Now just have to get the suspension stripped, and get the frame and suspension ready for sandblasting and paint.
Pat 1967 F100 4WD
would you take a pic of that steering box and the pitman arm and how it all hooks together with the linkage. a pic from the drivers side would be great.
67nukeford
I may not get back out ot work on it for a few days, but I'd be glad to. I'll pm you when I have the pics!
Pat 1967 F100 4WD
thank you i have been trying to get anyone to post a pic of this setup but so far no one has . thnak you.
67nukeford
I will stop out there tonight and get a pic for you, not a problem!
Pat 1967 F100 4WD
67nukeford
Here are a couple of pics, let me know if you need anything else! :thup:
Pat 1967 F100 4WD
