Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
Madman
Re: Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
Post by Madman »
popeyes71 wrote:Great progress! I was wondering how your project was coming along. The cab looks pretty clean inside. :thup: That will save a lot of time and make things a little easier on your restoration. I was wondering what the metal tab was that is next to your steering box, that protrudes out above the frame rail?
That was where the previous owner welded a flange to fit up a power steering unit. I prefer manual, so I am going back to original
2017 Ford Raptor
1975 Ford Bronco
Madman wrote:That was where the previous owner welded a flange to fit up a power steering unit. I prefer manual, so I am going back to original
Manual is OK but it's hard on column bearings. Plus, first time you get that big thing in a parking lot you'll want manual, trust me. :thup:
Oh yeah, try to mock up your brake lines before you put the cab on. I didn't replace mine, wish I had and the proportioning valve location sucks. Also check that the switch on top isn't made or the brake warning light will stay lit up. It's a real bear to center the plunger once everything is together, don't ask me how I know.
Project looks awesome and I like the idea of the tank under the rear. Really miss the space behind the seat.
popeyes71
Post by popeyes71 »
-Popeye-
1971 F-250 4x4 Highboy
popeyes71
Post by popeyes71 »
Sorry about the reply submittal above.........Thanks, I was wondering what that tab was. Yeah, as for manual steering, I still have manual steering in my Highboy and it works fine and I like mine too. Every once in a while I do wish I had power steering but not enough to install it yet. Keep us posted on how the project is coming along.
-Popeye-
Madman
Post by Madman »
My 71 had manual steering, and all my flat fender jeeps do too, I never found it to be that bad, perhaps when backing a trailer in a tight spot, but I'm not sure if that would ever supersede the freaking mess I had to clean up from the leaky arse system.
2017 Ford Raptor
1975 Ford Bronco
Craigerf100
Post by Craigerf100 »
I have 10in wheels on the front of my truck and I have always wondered how difficult it would be to drive if I did what I want and swop it to manual steering. I've never liked 60s era power steering, it's either over zelous or doesn't work. With either one u can't feel the road.
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
Madman
Post by Madman »
A little update here, the cab has been stripped of almost all interior components (just the wiper arms to remove) so we transferred it to a larger trailer so I can lay it on its backside then sand blast the underside and then seal it with rust encapulator as a precaution, even though the amount of rust is minute. When that is done I will roll it back over, blast the inside then out side, and replace it on the frame for forward progress.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Got the cab on a wider trailer to tilt it for sandblasting!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
The underside is pretty clean and in damned good shape for a 1970. Tomorrow the sandblasting begins!
:woohoo:
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Sandblasting underway!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Uncovered a little issue
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Eastwoods Rust Encapsulator applied
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Close up of the cab corners, they look great! Extra cot of encapsulatr here
2017 Ford Raptor
1975 Ford Bronco
1968-f250
Post by 1968-f250 »
Wow, that cab is in good shape! I wish mine would have been in that condition when I started.
Keep the updates coming. :thup:
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1957 Ford Fairlane 500 convertible (x2)
1979 Ford Bronco (x2)
1956 Ford Thunderbird
When the going gets tough, switch to power tools -Red Green
