Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
Madman
Post by Madman »
Starting with this!Image
Here is the beginning of my Project!
2017 Ford Raptor
1975 Ford Bronco
Madman
Re: Operation Spud...Pics being uploaded now...:)
Post by Madman »
Here is the Dana 44 with disc brakes (In the rough!!!!)
And lots of work and clean up to do!
In the Solvent Tank!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Beginning the rebuild. Looks much better!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
And a lot of work accomplished to fast forward to this picture!
Ready to install!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Pulling it into the shop to start the real work!
Wish the job ACTUALLY progressed as fast as scrolling through the pictures!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Got the Mill pulled out!
Opened up the oil pan...looks like the nylon coating on the timing gear is failing!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
A little out of synch....pulled the bed and pressure washed what I could.......
2017 Ford Raptor
1975 Ford Bronco
Alstoyz
Post by Alstoyz »
Looks like you've got a good start on a SAWEET project. Keep up the good work and keep us updated... :thup:
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
Madman
Post by Madman »
Alstoyz wrote:Looks like you've got a good start on a SAWEET project. Keep up the good work and keep us updated... :thup:
I am quite a bit farther than the pictures show, I am down to the frame and installing the differentials as I rebuild them. I am trying to catch up with the photos now that I know what I am doing!
Thanks you! I am pretty proud of my progress as I do all the work myself, I am only disappointed I am not further along.... :wink:
2017 Ford Raptor
1975 Ford Bronco
Truck looks like it was in really decent shape before you started. That should make it turn out so much nicer int he end for a lot less effort vs. what so many others have to deal with.
What color is your interior? My '70 was the dark green with a yellow body.
BTW, I'm on year 6 of restoring mine...
Madman
Post by Madman »
Ranchero50 wrote:Truck looks like it was in really decent shape before you started. That should make it turn out so much nicer int he end for a lot less effort vs. what so many others have to deal with.
Thank you. I am really strong in restoration with everything BUT body work....it is so time consuming (although I must say the little damned needle bearings in manual transmissions at times result in my excessive cursing!). I decided to replace the bed with one that did not have saddle tanks, but the big deal was the Cab was almost perfect, there is one minor rust spot in the drivers side floorboard that I may cut and replace or may treat very heavily...It was a Nevada truck.
The interior was also dark green with the funky yellow paint job.....I am having a hard time finding things like the original stye belts in the same color.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
A tired old 360...
Yup, I called it on the timing gear coating!
Now to get that pesky cab off!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Pulled the seat....floorboards and cab look great for 43 years old!
This looks easier than it really was!
Other than the excessive greasing of U-joints...pretty dang clean for the underside!
Another view!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Got it on my small trailer to move around. My 48 Willys is the perfect size to move the cab!
Time to pull drive train and start cleaning the frame!
2017 Ford Raptor
1975 Ford Bronco
Lot of progress! Good work. :thup:
