They bend well with the weight of a tank on themhfdco4 wrote:Well as you know, these things have springs that do not bend very well at all...LOL.
1970 F250 4X4 Rebuild / Updating
- Manny
Re: 1970 F250 4X4 Rebuild / Updating
- hfdco4
That is funny Manny! I received all the bearings for the front axle so I have stuff to do tomorrow.
FE390PC
FE390PC
- hfdco4
Got a little done tonight in prep for tomorrow.
FE390PC
FE390PC
- Manny
Your close to roller!!
- hfdco4
Got back at it today. Painted the knuckles. Got the top of the axle cleaned and painted. Installed the races in the cleaned hub.
FE390PC
FE390PC
- hfdco4
Hub
FE390PC
FE390PC
- Manny
What ratios you running here 4.10's. I don't know why but i love the axle work its just good fun. Also if you run into anything you need for that axle i have another one in the basement if you need anything for it let me know.
- hfdco4
Can you send me some pictures? I may need the shields, caliper brackets and calipers.
FE390PC
FE390PC
- Manny
WIll do i got the whole thing. Don't get your hopes up on the shields but i don't run them on alot of stuff. Both broncos and my brothers 350hfdco4 wrote:Can you send me some pictures? I may need the shields, caliper brackets and calipers.
- hfdco4
More done!
FE390PC
FE390PC
- hfdco4
Back at it again today. Finally got the lower ball joints to tighten, what a pain! Also got one Caliper Bracket cleaned and painted. Modified the brake dust shields I got at the swap meet earlier this year. Now I just have to tight the two top ball joint nuts and install the cotter pins. Did get the passenger side somewhat assembled.
FE390PC
FE390PC
Nice that axle looks new! I'm excited to see how you like your upgrade.
Kyle
Kyle
- hfdco4
I think it will be a great upgrade. The disc brakes and parts availability are already big improvements.
FE390PC
FE390PC
Plus it's a heck of a lot easier to work on disc brakes and swap pads!
Kyle
Kyle
- hfdco4
So true. I was able to get the other axle u-joint for Advance Auto at 25% off too. Don't think I will get to play with it till Friday though. I just want to get the axle back on the frame so it can be moved out and the cab can come back inside for that work over the winter.
FE390PC
FE390PC
