67' longbed build
1guydude
Re: 67' longbed build
Post by 1guydude »
Also ordered new rubber for my door seals. Need to do new felt for the windows as well. :/.
Ill take some pics of the radiator shroud. They r hard to find maybe? Id go junk yard for trucks... i broke mine sitting on it and zip tied it back together as u can see.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
Manny
Post by Manny »
1guydude wrote:Also ordered new rubber for my door seals. Need to do new felt for the windows as well. :/.
D
They sell replacements from dennis carpenter for the fan shroud. Just gotta verify your getting the right one. :thup:
1guydude
Post by 1guydude »
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
It was getting dark here but as u can see. Zip ties and bolts that have the mount on the other side. They just pinch the plastic. U can see in one of the pics though however a spot where a screw would go througb both.
Hths
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
2nd to last pic
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Disconnected my battery
Pulled my panel
It was cold out and my daughter was home. So i pulled it apart inside for cleaning and new needle paint. No windex! Dangit. Lol.
Pulling it apart
The plastic.lens piece just sits between. Ready for paint.
Below are pixs of the back and the part i changed.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Wiring looks good besides the connections. Gonna crimp new connectors and do this swap tomorrow hopefullys.
I did end up using metal.coat hangers for my current exhaust hangers... lol. Its a ghetto truck.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Taking it really slow. Trying to divide the jobs up into multiple days to fill some time. :/
It is what it is right now and it will get done more and more at a time now. Hey, i ordered parts and am doing something which is active and fwd progress.
When it comes to spring/summer i wanna get to body.
Need my buddy to come help with the welding. I have almost all the pieces i think ill need. Front passenger side needs some work. Than sand and more sand and more sand.
I will primer and glyde coat?! I think its called.
The thought of just wet sanding and clear coating comes to mind as well...
I need touch up paint for my interior. Stitch up a rip in my seat. Gonna ask my mom. Lol!
Need headliner. Need to spray the sound stuff and put my carpet in after all the metal and body work. O boy.
The bed im gonna cut out and put wood planks in.
Also need to fix leaks and change break lines and cylinders. New drums and pads. New tranny cooler. New blower motor for my heater. Sarg has a upgrade for me to do.
Edit. New.springs. shocks or struts or whatever u call em. New e brake and a horn and seatbelts. Would all b great in do time. :)
Thanks all for reading my blobs.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Well. I got the needle to ping to the full side. I need to pull the sender unit with the arm and float and see what happens when i swing it. Than re install.
Gonna pull the old rubber off doors. Hit the old glue gunk with a drill and wire brushs. What should i use on my new rubber door seals for install?!
Thanks
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Bullitt74
Post by Bullitt74 »
Looking good, getting some forward progress! :thup:
Steve F.
Red Deer, Alberta, Canada
8)
Manny
Post by Manny »
Still moving very good. Slow is how most projects go but that's fine it's looking good. :thup:
1guydude
Post by 1guydude »
How do i fix this?
She works properly. Wasnt hard at all. Shouldnt have put this off. I mechanically tested it and used a small.key chain flash light to.confirm the gas lvl was high. It was full.
Any guess what was wrong with the old one? :p lol
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Testing it outside the tank.
I used some orange paint from painting army guys.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
The done bed that needs some removal.and wood replacement. Also the old rubber from the doors
The doors after some wire brushing and heavy duty sand paper. Ill get it more when i actually do the seals. I still need to do more metal work.
Cmon spring.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
