67' longbed build
1guydude
Re: 67' longbed build
Post by 1guydude »
Just.got.back.from autozone. Guy there was a ford guy. Got new fluids..new gaskets. New.filters. Some wiring stuff. Hopefully i can get this motor ok. Than on to brakes and trans. Which i got fluid.for and thats about it if my.memory serves. Didnt have the new pan or screen.
Its.ok. more stuff.for.later.
Gaskets i got.were oil.pan. carb mount. Carb to air filter. O and the valve.cover gaskets. Which told.me its either a 360 or 390 motor. Think thats it. Easy hopefully.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1guydude
Post by 1guydude »
Well new info to.me. i guess u have to raise ur motor to change ur pan. I dont wanna.mess to.much with the pump and rod. Thatll be moved back on the list a lil. Lol
Update. Got her runnin. Got pix finally of that old.title i found in the headliner area.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Today the main job was finish scrapping the old gasket area with a flat head. Also a metal brush came in handy. I put new cork gaskets in. Ignitor got actual nuts on it so thats good. Fired right.up once i remembered i forgot the main line from the ignitor to the cap. Lol
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Well i went to change my fuel.filter and it is a screen.metal type. How do i get it.out? Ive turned it. Pulled.on it a lil. Its full.of rust. :/
Changed.my manifold.to.carb gasket.today. rain.stopped.me.from.doing the oil.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Ended up degreasing my motor on accident. :0
Forgot to tighten the hose clamp on my fuel line to the carb. Oops
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Lone Ranger
Post by Lone Ranger »
Make sure you rinse it off. I had a fuel leak on my old f100 and the gas dripped down and gathered on my radius arm bushing. Didn't take long and the bushing started falling apart. Then the steering went to pot.
Kyle
1guydude
Post by 1guydude »
Is that like an old school tie rod? A lot of those bushing already look pretty shot and i planned to attack em.one day here. Thanks though ill deff hose it all down.
Got a lot.of.stuff today and got.some work done.
New oil and filter. new fuel filter .new plugs and wires. All done.
Got a new cap and electronic igniton kit to eliminate.points and condensor. Im gonna wait on my buddies for this. Got the tranny filter. Some anti freeze. Vac module tranny. Should i replace the one for the distributer? Prob that hose too?
Changed a spongy hose from the carb to the tranny vaccum line. Done easy peasy
No more clamps and large hose for my fuel line either. New hose was tight but thats a good thing lol. Done
Tomorrow i would.like to bleed.my brakes. Any points tips or heads up? Was told the right rear tire is the one i wanna bleed. Is that passenger or driver side?
Was gonna submerge the line in fluid and let out the air well.all the other tires.are.on the ground...is that ok?
That and id like to work on my tranny. I got the new vaccum.module and some extra hose. New pan gasket and filter. Messy i.hope.not. thinking a.tarp.lay down and bucket or.something.
I replaced all but one of my fuses in my instrument panel.
The tiny stuby 14a. Ill find one here hopefully. Locally.
Trucks coming along. Pulled the bench seat today and it layed right over. Found an extra knob set up and an old crow bar. Score!
Lots to do. Ill get some pix so its not so boring and nooby mechanic talk.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
I tested both terminals on the alternator and they said positive on both. Or red. Red and green for neg.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Lone Ranger
Hey guydude maybe try a different battery. My truck was always dead and not charging. Checked all my wiring but ended up being a bad battery.
Kyle
1guydude
Post by 1guydude »
I actually wired in a new voltage reg plug today. I have more pixs ill upload later but i didnt have all 4 wires. Only 3. We will see..im excited to test and play with my new voltmeter. I should see increase if its working i think but will check on that when it comes. Battery is new.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Lone Ranger
You should only have the three wires. I think it's the black wire on yours possibly the green one... I know it's one of the outside ones doesn't belong haha. Did that take care of your problems? When I redid my voltage regulator wiring I sanded all the posts on my alternator to get good contact. Also sanded all my grounds.
Kyle
1guydude
Post by 1guydude »
I dont know i havent tried it out yet. According to the diagram/schematic on here. It shows 4. 3 wires and a ground wire. I unwrapped electical tape today thinking i would find exposed, frayed, brittle wires but most looked good. My ignition was wired into one of my alternator plugs. If that or i make any sense. Lol
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
