What the heck is this
jimmy828
Post by jimmy828 »
I did not know where to post this so i ended up here. I have been trying to figure what this part is :hmm: . It has an inside dimension of 1- 7/16 Can anyone help?
Re: What the heck is this
Looks like the spring washer from behind the turn signal switch?
MAK
Location: Georgia, Blairsville - Florida, Flagler Beach
Post by MAK »
sargentrs wrote:Looks like the spring washer from behind the turn signal switch?
That's what I was thinking too I remembered from my steering column disassembly a few weeks ago. It will be this weekend though before I am back up to my shop so I can measure it.
BobbyFord
Post by BobbyFord »
Where'd you find it?
jimmy828
Post by jimmy828 »
BobbyFord wrote:Where'd you find it?
Floating around in parts box. When i disassembled parts i would label them but apparently this part i forgot to log. :cry:
jimmy828
Post by jimmy828 »
I tried the Tech pages on steering column but could not locate the washer in the breakdown of column. I'm puzzled !
To be perfectly honest, when I rebuilt my columns, a 3spd and an automatic, I don't recall ever having one but according to this thread http://fordification.com/forum/viewtopi ... d1d13ec5a4 another member's was broken when he disassembled his column. I'm thinking it's #7C228 on the right, slightly above center, of this diagram, maybe? http://www.fordification.com/tech/image ... column.jpg
jimmy828
Post by jimmy828 »
sargentrs wrote:To be perfectly honest, when I rebuilt my columns, a 3spd and an automatic, I don't recall ever having one but according to this thread http://fordification.com/forum/viewtopi ... d1d13ec5a4 another member's was broken when he disassembled his column. I'm thinking it's #7C228 on the right, slightly above center, of this diagram, maybe? http://www.fordification.com/tech/image ... column.jpg
thanks Sarge. You might be right. I'm going to check it out this weekend. I'll let you know how it goes. Thanks for the help guys!
alphawave7
Post by alphawave7 »
That diagram suggests it sits *behind* the shifter housing? Maybe that's why I've never seen it...I did do the turn signal replacement and never saw that.
edit: n/m...I just read Green's post in that old thread. :yt:
MAK
Post by MAK »
Here is a pick I took of mine a few weeks ago when I disassembled mine. Hoping it would help remind me where the heck it went when I try to get this all back together... :P
It is about 1-3/4" diameter with an 1/8" face. It goes over the shift column and provides a little tension pushing against the face of the column housing and the shift collar. Actually fits over the inside lip of the shift collar that goes over the shift tube.
jimmy828
Post by jimmy828 »
MAK wrote:Here is a pick I took of mine a few weeks ago when I disassembled mine. Hoping it would help remind me where the heck it went when I try to get this all back together... :P
[ Image ]
Thanks for taking the time to post the pic. Just what i needed!. Such a minor fix for me but i thought it would go somewhere causing the job to be a pain in the ass. :fr:
