I'm building a 300... 5/19/12 SHE'S ALIVE!!!
Re: I'm building a 300... 2/04/12 top end assembled
Postby gregamorton on Sat Feb 04, 2012 8:37 pm
Looks super Nice!
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 4.10s rolling on 19.5s
1971 F250 crew cab 300 industrial Rug 3 speed OD dana 60 4.10sLS
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1993 dodge 350le cummins 518od with 3.55s daily driver
Possibly looking for my next bump right now!
gregamorton
Postby fomocoguy on Sun Feb 05, 2012 9:18 am
Thanks guys! It's just about done. I need to find grommets and things for the valve cover and find a carb, but it's close. In the mean time I need to get some material so I can start fabbing up my engine test stand. For those of you just tuning in, my plan is to run it on a stand so I've got it as dialed in as can be before I do the swap. I'd rather correct any  issues with it out of the truck than fight with it once it's in.
Joe
1969 F250 Crew Cab 4x4
2000 Jeep Cherokee Classic w/3" lift
fomocoguy
Postby fomocoguy on Sun Feb 05, 2012 9:21 am
woods wrote:Your dizzy recurve guy is shady.
Looking really good Joe.
Like, 5 oclock shadow shady or secret room where the 8 year olds are making t-shirts and cooking meth shady?
Joe
fomocoguy
Postby woods on Sun Feb 05, 2012 9:49 am
They really kinda go hand in hand.
woods
Postby fomocoguy on Mon Feb 13, 2012 10:18 am
Well, not much of an update but some stuff is getting done. I have my raw materials to build my test stand and will be starting on it today. I think I'm going to buy a factory y pipe to run some type of exhaust out the garage and I need to buy a carb still. This is going to make woods cringe, but a lot of guys have had good luck with the 500 cfm Edelbrock on these engines and I think I'm going to buy one. It should be ready to go out of the box for my initial run and break in, and it will be fun to tune since I've never really tuned an Edelbrock aside from basic adjustments.
Motor mounts, stat and housing, alt bracket, and carb flange are all installed.
Any advice on where to get the proper grommet and vent pipe for the valve cover?
Joe
fomocoguy
Postby fomocoguy on Fri Feb 17, 2012 8:17 pm
Engine run stand is pretty much done. Factory y pipe is on the way. New flywheel ring gear is on my bench and ready to be installed. I bought a very slightly used 500 cfm Edelbrock for $200 off craigslist so carb is ready. Hopefully in a few days I'll have pics of her all mounted up on the run stand.  :rock:
Joe
fomocoguy
Postby fomocoguy on Sun Feb 19, 2012 10:07 am
Just a few more shots with carb and various odds and ends installed:
Joe
fomocoguy
Postby fomocoguy on Mon Feb 20, 2012 5:20 pm
Got her all mounted up on the test stand today. Still need to fab up a panel for gauges and tach, but it's getting there!
Joe
fomocoguy
Postby Joeseph on Wed Feb 22, 2012 3:00 am
Looks like your using the fel pro intake gasket, when it fails replace it with the Mr gasket  260.  My truck is a DD  and although my engine isn't in need of a full rebuild and runs very well  I run the same intake/exhaust setup and that fel pro gasket is a fail.
Joeseph
Postby killakobra on Wed Feb 22, 2012 9:53 am
i have used both and i see little difference in seal. proper torque make more of a difference than the gasket. another problem with the mr gasket gasket is it doesn't have the added thickness of the seperate intake gasket to make up the manifold thinkness.
1967 f100 stepside 300ci I6
1972 longbed trailer
killakobra
Postby ANGELO1 on Mon Mar 05, 2012 1:46 am
a 300 is a big block 6. a real big big block. they arn't gas milage champs. have you thought about overdrive. gearvender, or ranger are both very stout units. so stout that you can split the gear when you are shifting. me in alaska driving in 4x and the od ingaged, still getting 18 with a warmed over FE. think about it
ANGELO1
Postby fomocoguy on Sat May 19, 2012 9:43 pm
As of tonight she is alive! I had a minor cam timing setback but after an hour of pulling the crank gear back off and getting everything lined up like it should be she fired off on the first try. I think it was pretty late and I was somewhat tipsy when I put that timing set in (thank god 300's are non interference engines). I knew I had a problem when fuel was puffing back out through the carb. Anyhow, she runs like a champ now! It sounds freakin' fantastic. It's like a cummins sound but with no diesel clatter. I took video of the whole thing, so as soon as I can figure out how to get it from my camcorder to photobucket I'll post it up.  :woohoo:
Joe
fomocoguy
Re: I'm building a 300... 5/19/12 SHE'S ALIVE!!!
Postby Ranchero50 on Sun May 20, 2012 3:45 am
New engines are always things of beauty.  Now get it in the truck and dirty like it should be. :)
'68 Ranchero 5.0 EFI 5sp 3.55's 3" stainless exhaust in black primer
'68 Fairlane 500 fastback 289 C4 46k miles pale yellow
'93 Mustang Lx 302 Calypso Corral (green) Paxton powered 390rwhp commuter car
'91 Bridgeport 308 CNC VMC You dream it I make it
Contact me for CNC Dome Lamp Bezels and Ash Tray pulls, more stuff coming.
Postby sargentrs on Sun May 20, 2012 6:19 am
That's awesome!
How come when your wife or kid's Japanese cars break down, it's always the beat up ol' Ford truck that comes to pick 'em up?
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding.
Stolen on March 2006 - recovered and returned May 2007. I am truly blessed.
Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
Postby fomocoguy on Sun May 20, 2012 6:36 am
Yep, pretty exciting stuff! I wasn't super motivated to get it into the truck until hearing it come to life. The wife was less than thrilled, as the first thing she said when I came in afterwards was "Are you done being noisy?", but I've come to terms with the fact that she'll never get it. Anyhow, here's a couple vids. I'm a little dissapointed at the sound quality; there is just no way the camcorder can capture the deep bass coming from this thing! Plus ya'll get to see me get a face full of gasoline while I'm getting the timing set :lol:
http://www.youtube.com/watch?feature=pl ... aAPp3VPOdU
http://www.youtube.com/watch?feature=pl ... m8uQQVn-sY
Joe
fomocoguy
PreviousNext
Return to Engine
