Yes that. I would also remove the pulley and check for wear marks anywhere in the area.But I am betting on the pump itself like DuckRyder is.Timd wrote:I have tried my stethoscope but with no luck, nothing sounds off. Are you saying to use bolts and washers and remove fan so i can eliminate the fan as the cause?TNIceWolf wrote:Personally I think I would remove the fan and use some oversize nuts and washers as spacer to hold the water pump pulley on and try that.I am a huge fan of my stethescope. It can get into places a stick or screwdriver cant. Most also have a long reach that helps keep your body parts away from moving components.
Engine noise
- TNIceWolf
Re: Engine noise
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- Timd
- DuckRyder
Re: Engine noise
Try feeling for roughness put light forward and aft pressure on it while hand turning...
- Timd
