1969 F-250 360 Holley 2bbl
- Haltech007
I have a '69 F-250 Camper Special with a 360, C6, and a Holley 2bbl with a manual choke. The truck is completely stock. Is this carb an original item? I have found plenty of old Fords that have the same carb, but I cannot find anything 'official' from Ford that says it was an original 1969 Ford-installed item. Did it come from Ford, or did everyone back in the day just bolt these on?
Re: 1969 F-250 360 Holley 2bbl
I've never seen any brand other than the Autolite used.
I have one that came off a '69 , and it sure looked original.
I still use it on another truck.
There should be a "list" number on the air horn , you can research it on a Holley site and find out the application.
- Manny
Holley's were on fords but i have never seen a 2300 on a 360 stock always the autolite 2100. and normally by 69" they used the heat style choke. plenty of holleys on ford but normally the four barrels. As above look on the front of the choke horn under the air cleaner for the model number you can find out what is was built for.
