Broken Exhaust Bolt
pchelp101
Broken Exhaust Bolt
Post by pchelp101 »
Any suggestions to remove broken bolts with no access to an acetylene torch or removing the heads
1969 F100, 390, 3 Speed, 2WD
Manny
Re: Broken Exhaust Bolt
Post by Manny »
Go get some good sharp drill bits... then patience. Some weld nuts then extractors and all. I am guilty of just going old school and drilling them out. Might have to pull a inner fender for access though or have a right angle drill. :2cents: I am guessing FE 360-390 top flange bolts.
pchelp101
Post by pchelp101 »
Manny wrote:Go get some good sharp drill bits... then patience. Some weld nuts then extractors and all. I am guilty of just going old school and drilling them out. Might have to pull a inner fender for access though or have a right angle drill. :2cents: I am guessing FE 360-390 top flange bolts.
Nailed it, 390 top bolts on the exhaust
cep62
Post by cep62 »
How many ?
If just one I've seen people put a clamp on it.
Crude but effective.
idaho_cowboy
Post by idaho_cowboy »
One of my recent projects, when I bought it, had several broken bolts in the top flanges on a 360. I decided it was the perfect opportunity to pull the heads, get them re-done, and put it all back together with a new set of hookers.
Sometimes that's easier than spending hours on end trying to fish out a broken piece of ancient metal out, while installed in the truck.
- Joseph
Owner @ bumpsidetreasures
RottenAppleRed
Post by RottenAppleRed »
Make sure they are flat (die grinder helps.) the above post for sharp drill bit is right on. Definitely center punch the bolts to keep the bit from walking. Even if you ruin the threads in the head, a nut on the back side will do the trick.
pchelp101
Post by pchelp101 »
cep62 wrote:How many ?
So far the last two top bolts on the drivers side.
pchelp101
Post by pchelp101 »
idaho_cowboy wrote:One of my recent projects, when I bought it, had several broken bolts in the top flanges on a 360. I decided it was the perfect opportunity to pull the heads, get them re-done, and put it all back together with a new set of hookers.
- Joseph
That would be my last resort, wife is already tapping her toes at how long it's taken to replace a "gasket" :cuss:
pchelp101
Post by pchelp101 »
RottenAppleRed wrote:Make sure they are flat (die grinder helps.) the above post for sharp drill bit is right on. Definitely center punch the bolts to keep the bit from walking. Even if you ruin the threads in the head, a nut on the back side will do the trick.
It's a good thing I already had the column out to be replaced, looks like I might have to drop the master cylinder too
idaho_cowboy
Re-using the stock manifolds?
If so, have a machine shop mill them flat (true), and then don't use a gasket..
pchelp101
Post by pchelp101 »
idaho_cowboy wrote:Re-using the stock manifolds?
The stock manifold is shot, cracked right in half
tnlprt
Post by tnlprt »
Pop the lower radiator hose off
4 plug wires
5 valve cover bolts
4 rocker shaft bolts
2 exhaust bolts
5 intake bolts
10 head bolts
The head can be removed in less than an hour
pchelp101
Post by pchelp101 »
tnlprt wrote:Pop the lower radiator hose off
4 plug wires
5 valve cover bolts
2 exhaust bolts
5 intake bolts
10 head bolts
How do you get a good seal on the manifold?
pchelp101
Post by pchelp101 »
One down and the worst possible thing happened on the second. Had a good grip with the easy out and it snapped off inside the bolt :cuss: Now I am slowly trying to drill out the easy out ugh
Ohiotinkerer
Post by Ohiotinkerer »
Joseph,
Has that worked for you? I've always used a gasket even if I had them machined - just did it to the '68 because it had a leak on #3 and put new Fel-Pro gaskets - afraid it would leak if I didn't........ :eek:
1997 Honda CBR 900RR
