Oil pan.
JohanNB
Oil pan.
Post by JohanNB »
Ok, here we go again...
Since you guys managed to help me out in a wonderful way last time I'll give it another try...;)
But this time it's the oil pan. I want to replace the gasket and have removed all 20 bolts. But at this time you just don't remove it huh??!?
Do I need to remove anything else to get it out?
Yes I'm a beginner... :roll:
JohanNB
Re: Oil pan.
Post by JohanNB »
It's a F250 -1970 with a 390 engine...
Jacksdad
Re: Oil pan.
Post by Jacksdad »
I believe you have to unbolt the motor mounts and either jack the engine up to get clearance on the crossmember, or pull the motor.
8ton
Re: Oil pan.
Post by 8ton »
The oil pump and pickup tube need a lot of space to clear, or be removed to get the pan off in the truck. I think the engine needs to be jacked up and a 2x4 chunk wedged between the motor mount and block on either side.
