oil pickup tube torque specs
madtom
Post by madtom »
I'm wondering if anyone can provide torque spec for the bolts connecting the oil pickup tube to the oil pump? Its a 1972 360 F250 four wheel drive.
My rebuild manual doesn't list a recommendation for them and a google search didn't help any. I do have the specs for oil pump to block.
Also, should these two bolts have lock washers? I only ask because so far, they're the only two bolts on the inside of the engine with lock washers and I want to be sure I'm not mixing anything up.
colnago
Re: oil pickup tube torque specs
Post by colnago »
I used the yellow "Big-Block Ford Engines" book. It says oil pump and pickup tubes are both 12 - 15 ft-lbs. It didn’t say one way or the other about lock washers, and I can't remember whether mine had them or not. Maybe you can find an engine schematic that shows it in the tech section.
madtom
Post by madtom »
Thanks Colnago!
Ron_Hall
Post by Ron_Hall »
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
