hello,
can somebody help me with the correct ignition timing for my 1971 ford f250 360 engine.
also need spark plug gap
points settings
thanks
1971 360 ign timing
- HIO Silver
Re: 1971 360 ign timing
6° BTDC
Spark gap is .035
.... dunno about points. I use a Pertronix module
Spark gap is .035
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Feeler gauge is .017mike mandemakers wrote:points settings
Better way is with a dwell meter and my memory thinks its about 28-31 degrees.
- Manny
Everything above is spot on correct by the old 71' book here. However i might say tweak you timing up to 10 before TDC. They backed it down for emissions but they run crisper in my mind at 10-12. May be worth a little experimenting.
- My427stang
I agree, set to 10-12 and forget it. The low compression and loose quench of a 360 likes more timing. If the truck is worth a little investment, a recurve will add even more. You could go 14-16 initial, and with a recurve could limit total to 36-38 and have it all come in quicker. It's not magic on a 360, but a noticeable part throttle and a little mileage improvementManny wrote:Everything above is spot on correct by the old 71' book here. However i might say tweak you timing up to 10 before TDC. They backed it down for emissions but they run crisper in my mind at 10-12. May be worth a little experimenting.
As stated above forget the factory spec. Go to 10-12 BTDC and see how it runs. I set mine as high as I could without pre-detonation which I believe was 13-14BTDC. I can get 15mpg if I drive it correctly and low end and cruise is way more responsive. I also have a Mallory CDI ignition, Accel coil and Pertonix Ignitor on it, though it worked nearly as well before I installed the Mallory box. You can also just use a CDI ignition like MSD or Mallory and trigger it with points. The points last a long time because they only provide a ground signal for the CDI box to use as a signal to fire.My427stang wrote:I agree, set to 10-12 and forget it. The low compression and loose quench of a 360 likes more timing. If the truck is worth a little investment, a recurve will add even more. You could go 14-16 initial, and with a recurve could limit total to 36-38 and have it all come in quicker. It's not magic on a 360, but a noticeable part throttle and a little mileage improvementManny wrote:Everything above is spot on correct by the old 71' book here. However i might say tweak you timing up to 10 before TDC. They backed it down for emissions but they run crisper in my mind at 10-12. May be worth a little experimenting.
If you decide to upgrade the ignition at all the use of a higher resistance coil is a must. The engine will start much easier with a hot coil and a bump in initial ignition timing. The problem is that you either need a Pertonix (or Duraspark distributor) and 12V to the coil or a CDI ignition. One advantage of the CDI ignition boxes is that they can be hooked to the stock resistor wire which is only about 10V. The box only needs between 7-14V to turn on, all of the current for the system actually comes directly from the battery, so no need to replace the resistor wire. I ran a hot coil at full 12-14V with points for a while and it ate the points up very quickly, they needed adjustment about every 150 miles.
I know I am getting long winded here but in my experience with all FE engines is that ignition setup is the biggest improvement you can make in reliability and drivability.
