Woodruff Keys on Cranshaft Questions
colnago
Post by colnago »
My rebuild project had one Woodruff Key in the crankshaft. This is great for the timing gear, but it,s not long enough for the harmonic balancer. My basic question is, did Ford use two separate Woodruff Keys on the FE engines? My second question is, does the curve go towards the harmonic balancer, or towards the crank?
Thanks,
tsherry
Re: Woodruff Keys on Cranshaft Questions
Post by tsherry »
Curve goes toward the crank. Can't answer the other question for an FE, but on a 351, there's a single key to handle both.
or, money.
tnlprt
Post by tnlprt »
2 keys ..
Half moon for the gear
1/4 inch key stock for the dampner
Manny
Post by Manny »
tnlprt wrote:2 keys ..
He is dead on the money... :thup:
colnago
Post by colnago »
Does anyone know how long the key stock should be? I know my local True Value carries pre-cut sizes, but I'll have to go in there with a ruler and my harmonic balancer.
tnlprt
Post by tnlprt »
Just buy a 3 inch piece and cut off what you need
