Oil pan gasket
1guydude
Oil pan gasket
Post by 1guydude »
It.dosent need to be done, but probably will need to be done in the near to not so distant future.
Ive done some research and it looks like i will have to take out my motor mount bolts and raise my.motor to get out the pan and such.
I will use 2×4s and wedge it up. My question is. Do i need to unhook my tranny anywhere? Or can i just go at it and everything will angle up with the motor?
Basically im looking at changing my oil pan gasket, pickup gaskets, and clean the.screen.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1guydude
Re: Oil pan gasket
Post by 1guydude »
Truck is a 67' f100 with 390 and c6
Thanks!
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
colnago
Re: Oil pan gasket
Post by colnago »
I think you'll be okay, but you should lossen or remove the rear mounting bolts on the tranny, since it will need to tilt up. Other than that, the U-joint should protect the driveshaft.
