95 F350 ford engine
95 F350 ford engine
Found the above truck for cheep. Has the fuel injected 460 rebuilt and a good tranny. Would there be any benefit to pulling out the 360/C6 from my F250 and put this in? I am not going to be using this truck to haul anything, its been retired.
Re: 95 F350 ford engine
I'm thinking not really. If the 360/C6 combo is working for you and is in sound mechanical condition, why go through all the work? I sometimes think about doing this very swap, EFI, OD trans, a little more power etc. My 390/C6 combo works great, gives me zero problems, and hauls loads that are sometimes way over what it's rated for. I have to tell myself the old saying; "If it ain't broke, don't fix it." Just my .
Mark.
Mark.
1975 F-250 4X4 (The Beast)
1971 Bronco Sport
1971 Bronco Sport
- Manny
Build ya a good 390. Have more pep than the smogger 460. they were only 225 like 385 ft lbs later years. Big blocks are great early years with high compression and all.
- bluef250
Only if the 360 is not healthy. Otherwise you might put the truck on Craigslist for someone else to use.
