Idle RPM's for 300 I-6
wildcard
Post by wildcard »
I have a 300 I-6, 3 speed manual with electronic ignition.
I'm trying to get it running better so I would like to go back and get everything set back close to specs and adjust from there.
I have the timing at 10°.
What would be the ideal idle RPM's on this?
Once I get this, then I can start tweaking the timing and carb.
Thanks
1972hiboy
Re: Idle RPM's for 300 I-6
Post by 1972hiboy »
I would think in the 650-750 rpm neighborhood. :hmm:
Rich
Dont eat yellow snow.....
eggman918
Post by eggman918 »
550 RPM for 1972 and earlier
Steve
wildcard
Post by wildcard »
Ok. Thanks.
WarEagle
Post by WarEagle »
wildcard wrote:I have a 300 I-6, 3 speed manual with electronic ignition.
Thanks
Is it a stock motor?
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
wildcard
Post by wildcard »
Everything is stock except the electronic ignition.
Manny
Post by Manny »
650-750 is where i would set it. With the 3 speed you have a little lee way.. :thup:
WarEagle
Post by WarEagle »
I'm at 680-700 rpm in park, 560-580 in drive w/o choke. I have a mild grind cam built for torque. power band is something like 800 rpm to 3000 rpm.
jzjames
Post by jzjames »
My OLD 300 I6 is at 550.
Gives me a sense of how tuned up we are. 8)
wildcard
Post by wildcard »
I haven't gotten far with mine. I got out and changed the rubber parts of my fuel line. I had to wire up a lever of some sort that's between my carb and choke to keep it from dropping too far when the choke releases. That was a week ago. Since then, it's either been too cold or my arthritis has been too bad. I sure hate cold weather.
Manny
Post by Manny »
wildcard wrote: I sure hate cold weather.
No doubt..... :doh:
wildcard
Post by wildcard »
OK, I got the RPM's set at 700.
I'm gonna start a new post on my carb.
Thanks for everyone's help and comments.
