I plugged the oil breather on my ‘70 F100 302...
Sisujoel
Post by Sisujoel »
... and now I’ve got oil blow-by spray on the passenger side of the engine compartment. :cry: The drivers side is clean and dry. I realize (after reading forum posts thinking I may have a leaking valve cover gasket) that I made a boneheaded :roll: mistake by plugging the breather cap. The breather cap is original and I learned that it would’ve originally had a hose routed from it to the air filter cover. When I acquired the truck it had no breather hose and a mismatched air filter cover so I installed an aftermarket open flow style air filter holder.
Questions: what possible damage might I have done by plugging the breather cap? Fortunately I only drove the truck a couple times for short distances before noticing the oil spray. What would be the most likely source of the passenger side oil leak/blow back? Valve cover gasket? Since I don’t have an original air filter cover to route the breather cap to should I replace the original cap with a mesh filter style breather cap?
Live and learn. :help:
Jacksdad
Re: I plugged the oil breather on my ‘70 F100 302...
Post by Jacksdad »
I guess there's always a chance you could damage a seal or unseat a gasket, but you probably didn't do anything other than make a mess.
Busboy
Post by Busboy »
There would be no permanent damage but it sounds like the engine is toast with that amount of blowby.
1967 F-100 4x4 custom cab.
tnlprt
Post by tnlprt »
The original breather cap had the hose routed to the air cleaner for only one purpose.
To filter the air being sucked into the crankcase
A mesh or K and N style breather will work just fine.
Likely no damage occurred.
Blow by is a product of ring seal ..Live with it or rebuild it
The most you have done is blown the valve cover gasket or the end seals on the intake . Hope for the valve cover gasket.
Sisujoel
Post by Sisujoel »
I appreciate the replies. Lesson learned.
