F100 360 Y pipe Front pipe
Ranger xlt
Post by Ranger xlt »
Hi guy's i'm looking for a Y pipe and Front pipe for a 1970 f100 360 engine 2 wheel drive. I found these Walker part numbers. Y pipe #40516 and Front pipe #42371. I found these on the Walker site but lists them for F250 anyone know if these will fit. Is there another make that will work. Thanks for your help
Busboy
Re: F100 360 Y pipe Front pipe
Post by Busboy »
I've used those on my trucks. It seems like their website leaves stuff off but much of it will fit other years.
1967 F-100 4x4 custom cab.
Ranger xlt
Thank's Busboy one less thing to look for.
colnago
Post by colnago »
I tried using the Walker stuff on my '67 352, and it definitely did not fit. One of those parts that didn't cross over, I suppose. I ended up having a local shop fab up a system.
Busboy
Post by Busboy »
They fit perfectly on my 67 f-100 with a 352. I replaced the entire system from manifolds to tail pipe and it worked out perfectly. :? :?
colnago
Post by colnago »
Busboy wrote:They fit perfectly on my 67 f-100 with a 352. I replaced the entire system from manifolds to tail pipe and it worked out perfectly. :? :?
Hmmm, not sure. Maybe it was an F100-vs-F250 thing. I just remember that it didn't fit, and it was a bit of a gamble, because the Walker web site fitment guide didn't specify a '67 F250 with a 352. Or, they've changed their design.. At the time, I shrugged it off, and took the truck to a local shop.
