Compressor Question?
I know this probably is the right area but just need a quick response to this question. At walmart they have an air compressor that has all the tools and stuff but doesn't say what hp it is but says it can run all those air tool if anyone seen it, or do i just go with the campbell brand 5 hp that can run the tools longer i don't know what do you guys think? let me know asap sending wife there today....Terry
The dumbest question in the world is the one you don't ask.
re: Compressor Question?
It's probably too late...but when looking at an air compressor you really need to know the HP and the CFM output before purchasing...and the CFM rating is actually more important than the HP rating. Plus before we could really offer a recommendation we'd need to know how you intend to use it. Would it be strictly for running basic air tools, or do you think it could be used for air-intensive jobs like sandblasting or painting. If it's going to see some heavy-duty use, you really shouldn't settle for any less than 13-15 CFM minimum...and that's cutting it close. Anything less and your compressor will be exceeding the duty cycle to keep up with the demand, meaning it's going to get hot and burn up before it's time.
thanks keith and spartman i will keep that in mind when i get one...Terry
- 72hiboy4x4
- Location: As far away as I can be from Wa state, without crossing the Mississippi
if you like your ears, try to avoid a direct drive compressor. I have a craftsman 6 hp DD and you cannot have a conversation with it running nearby (like 1/2 mile away). not to mention waking the neighbors if it comes on in the middle of the night.
but I must say I am happy with it otherwise. runs everything I can throw on it, and fills a 60 gallon aux. tank also.
at least 8 years and still going strong!
I got the same one. Mine threw a rod and kept going. It's loud, but
it works good.
it works good.
- rjewkes
got a CH 4 gallon 2 horse with 7 cfm i was thinking basic air tools and the occasional ball or tire. If i got it to fill a 10-60 Gallon aux would it be a little better?
fuelly.com
fuelly.com
Forcing a small motor & pump to fill a large tank is just causing it to work past it's duty cycle and is a sure way to burn it up.
- rjewkes
ok than skip on the lrg tank. would an extra five gallons work? Or do i use this for small jobs and buy one for the bigger jobs?
fuelly.com
fuelly.com
- flyboy2610
Basically... yup!rjewkes wrote: Or do i use this for small jobs and buy one for the bigger jobs?
Red Green
you'd better be right.
Red Green
a few years ago, I bought the C/H compressor ( 5 hp ) from Walmart with all of the tools. I thought I could spray with it...forget that. Spray 15-20 seconds....wait 3 minutes for the compressor to catch up....blah. Sold it ( kept the tools...actually came out ahead ) and bought a 7hp 80 gal 230V ...I think it is 15-16cfm at 90psi...but I could be wrong. I love it..but could use bigger! It has a hard time keeping up with my sand blaster. Bust out the credit card and get the biggest you can fit in your garage.
I totally agree. Buying an air compressor is one area a person should NOT skimp....buy more than you can afford, because you WILL use it's full capacity if you have it.
Like I always say: It's better to have it and not need it than to need it and not have it. And this is especially true with air compressors. Bigger IS always better.
