Air Filter
Engine Forum Archives
Moderator: Ranchero50
Jimbo
Air Filter
Post by Jimbo »
Have a 302 engine 2bbl I want to put a new custom air filter on it but how do I get around the vent for the pcv coming out of the rocker cover I think the other side has the same type of set up. Any information would be helpful
heep70
re: Air Filter
Post by heep70 »
Take a look at this thread. There is a picture at the bottom that Keith posted that will help you out.
http://fordification.com/forum/viewtopic.php?t=733
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Jimbo
re: Air Filter
Post by Jimbo »
That did not help me. I showed only 1 picture and then it said nothing on where to route the tubes. I need to know where to put the tubes coming off of the value covers. jimbo
heep70
re: Air Filter
Post by heep70 »
The hose that comes off the PCV (pass side valve cover) goes to a fitting on the back or the front carb base. This hose (PVC) draws crank case vapor out of the block.
The hose that comes off the oil filler cap connects to somewhere on the airfilter housing. This hose pulls filtered air into the crankcase. After market filter housings usually have a place where you can punch a slug out and put a fitting in to connect to this hose.
That is what the picture is illustrating. Let me know if this helps. :)
Greg
Faithful Old Road Dog
re: Air Filter
Post by Faithful Old Road Dog »
Hey Jimbo, like Heep70 said, the hose with the PCV goes to the vacuum port of the carb or carb spacer. The other valve cover leads to filtered air. If that aftermarket air cleaner assemby does not have the punch out. You might be able to find a filter that pops directly to the valve cover. They look like a tiny air cleaner about 3" diameter. Maybe K&N carries one for your 302. The only thing is that sometimes you'll get oil leaking out of these types of vents/filters.
