clutch install 1970 f100
rhg
Post by rhg »
I am going to install a new clutch in my 70 f100 4x4. I was looking for any tips on doing the install the right way as appose to the trial and error method. Thanks in advance.
71PA_Highboy
Re: clutch install 1970 f100
Post by 71PA_Highboy »
get a full kit... Clutch, pressure plate, throw-out bearing, pilot bearing.
If you can, get a 100% sintered bronze pilot bearing.
Pull ONE bell housing bolt. Go to the hardware store and buy 6 bolts that are the same thread pitch as the one you removed, but 6" long.
Drop both driveshafts, put a floor jack under the t-case, with the wheels of the jack fore and aft. Remove cross member
Pull the starter, replace all the bolts with the longer ones you just bought.
Remove the shifter linkage.
Slide the trans/tcase back, supporting the the bolts and the jack.
Remove pressure plate, clutch old pilot bearing, throwout bearing. Remove flywheel, have it resurfaced.
Reverse procedure for re-installation.
YMMV, I am doing this off memory... ;)
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
HIO Silver
Post by HIO Silver »
71PA_Highboy wrote:get a full kit... Clutch, pressure plate, throw-out bearing, pilot bearing.
After ya buy those long bolts, do ya gotta cut their heads off ? Or are the heads left on the bolts to prevent is sliding any further back?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Madman
Post by Madman »
Don't forget to look at the flywheel surface and inspect it to determine if it needs to be surfaced or not.
2017 Ford Raptor
1975 Ford Bronco
rhg
Post by rhg »
The cross-member is huck riveted in...
