Hard to get my 79 f100 to take off.
ARhodes1974
Post by ARhodes1974 »
I have a 79 f100 and its hard to get it to take off. I changed the fluid and strainer in it today. I have to rev the motor up high and it eases off slowly. Once it gets going it drives pretty good all the gears are changung out good and stuff.
colnago
Re: Hard to get my 79 f100 to take off.
Post by colnago »
Just a stab,but my 352 has very low vacuum. If it's cold out, it has real problems shifting. Do you have a vacuum gauge? If you don't, you should! Anyway, hook it up and see how much vacuum you're pulling.
ARhodes1974
Thanks colnago i dont have one but im going to invest in one asap. Im thinking it might be the modulator but im definitely going to pursue getting a vacum gauge.
jzjames
Post by jzjames »
Standard transmission?
Is the motor tuned up and running on all cylinders? Could it be your clutch?
ARhodes1974
It is an automatic and i just changed the plug wires distributor cap and rotor button on it the motor is running strong i was told it could be the stall in it. It has a small cam in it.
ARhodes1974
Thank you guys for all of your help it was the modulator valv . I replaced it and it drives like a champ now.
makes sense.
Bump the timing to 15` initial ad it'll run better too. Stock is too retarded.
