Finally got the Kickdown Cable installed
windhamdw
Post by windhamdw »
Finally got it on and it work perfect, i did have to get a longer bolt for the trans mount because it was to low.
Busboy
Re: Finally got the Kickdown Cable installed
Post by Busboy »
We call that " afro engineering" :D
1967 F-100 4x4 custom cab.
colnago
Post by colnago »
Well done!
