Got a 71 Camper Special that I am working on. A few months ago I swapped out the points for a petronix system. slapped in new plug wires, and got the blaster coil. Started the ole girl up and she was purring.
FF to now, rebuilding the front suspension, everything is off and getting powder coated, I thought I would fire her off again just to keep the engine rotated. Connected the batt, has a good charge, turned the key and nothing, no even a crank or sound from the starter sol. I have power, lights come on. I was able to start the truck in park and neutral before, but now, nothing in either position. Shifter lever is loose anyway on the tranny not sure if that is effecting this issue. Besides maybe that, any thoughts to look for anything else? Looking at the shift arm on the C6 tranny, does it move up to go from part to drive or down? I want to see if maybe I am binding in the at the shift lever or in the steering column.
not starting, C6 shifter lever issue?
- BobbyFord
Re: not starting, C6 shifter lever issue?
Can you jump the solenoid?
Maybe adjust the neutral safety switch.
- colnago
Up is Park, but even if you were binding, you shoulg get something from the starter. I would suspect the neutral safety switch. Mine is really finicky. Sometimes I have to jiggle the lever for it to start. Do you get any power to the coil?
