Ford C^ Overdrive
Timd
Ford C^ Overdrive
Post by Timd »
Hi all,
I have a C6 tranny that has overdrive, it doesn't have anything special attached to it, my question is, I have been reading that Ford never made a C6 with overdrive, if I have a C6 tranny that jumps into overdrive when I floor it then where did it come from?
1969 Ford F100 Custom Cab
302
1972hiboy
Re: Ford C^ Overdrive
Post by 1972hiboy »
Gear vendor?
got and pics?
Rich
Dont eat yellow snow.....
Post by colnago »
Are you sure that's overdrive? The C6 has a shift-down lever; when you floor it, the C6 downshifts to second so you have some oomph for passing.
1972hiboy
Post by 1972hiboy »
colnago wrote:Are you sure that's overdrive? The C6 has a shift-down lever; when you floor it, the C6 downshifts to second so you have some oomph for passing.
oooh that makes more sense. For a C6, overdrive would mean a fourth gear. But down shifting into passing gear is not the same as overdrive. I recall being confused with that sort of terminology when I was younger.
Rich
Timd
Post by Timd »
Ah I bet the shift down is it, that makes sense.
Thank you
302
