HELP I CANT SEE
Electrical and Wiring Frequently Asked Questions
hunter01762
HELP I CANT SEE
Post by hunter01762 »
Hey guys i drove my 69 to the shop last night and the headlights kept blinking on and off but only on highbems, lowbeams run fine is this the dimmer switch or could it be something else???
:hmm:
Lord, give me the restraint not to cuss over busted knuckles.
flyboy2610
re: HELP I CANT SEE
Post by flyboy2610 »
I would replace the dimmer switch first.
There is a circuit breaker in the headlight switch, but I would think if that was going bad, you headlights would blink on low beams, too.
Red Green
you'd better be right.
hunter01762
re: HELP I CANT SEE
Yeah it is like I can switch the high beams on and they would work for a minute and then go out dash lights too. thats a bad feeling when your doing 65 in the middle of nowhere surrounded by trees.
Heavenlyfire
Post by Heavenlyfire »
I agree with flyboy, I would do the dimmer first, and it not then the switch itself.
oldhalftons
Post by oldhalftons »
the high beams pull just a little bit more amperage through the headlight switch and its tripping the breaker in the switch, eventually it will do it on low beam too. its not the dimmer switch.
I've just been through this flashing headlight problem
1969 F100 300/4spd power steering, manual brakes
yea when my high beams go out they stay out because the dimmer switch is stuck in the down position, i pry with my shoe on the side of it and it pops back up and the lights come back on.
Jake11
Post by Jake11 »
The headlight switch has a built in circuit breaker
guys! It goes bad and your lights will start blinking
off and on. The dimmer is a problem too. It's on
the floor in the worst place. Do um both. Ck. the
plugs for burnt looking connections too.
heep70
re: HELP I CANT SEE
Post by heep70 »
Headlight switch :thup:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
