Leaf springs on...but are they wrong?
Postby JWW on Mon Apr 30, 2012 3:49 pm
I thought I took pretty good pictures of my leaf springs before removing.  However, to be honest, I didn't realize that one sid was longer than the other in relation to the bolt that holds the leafs in place.
I finally got them put back on and felt pretty good about it, but I wanted to run it by you all as well.  I put the shorter side (about 23" to the center bolt) towards the front and the longer side (about 27" to the center bolt) towards the back.  It seemed to look right.  What are your thoughts?  Thanks
JWW
1967 F100 Ranger, Auto, 240ci
2001 F150 SuperCrew
JWW
Re: Leaf springs on...but are they wrong?
Postby elgemcdlf on Mon Apr 30, 2012 4:55 pm
That would be my guess & perhaps someone will chime in with concrete answer but you can always set the bed back on where it belongs. That should tell you quick enough.
elgemcdlf
Postby flyboy71 on Mon Apr 30, 2012 6:03 pm
Those are right based on mine.   Are they the original springs?  They look good.  Where did you get the spring pack clamps?  I need a set for mine since my spring packs are still apart after painting.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
Image Image Image
flyboy71
Postby JWW on Mon Apr 30, 2012 8:05 pm
flyboy71 wrote:Those are right based on mine.   Are they the original springs?  They look good.  Where did you get the spring pack clamps?  I need a set for mine since my spring packs are still apart after painting.
Thanks Flyboy.  Yes, they are original.  I did have an extra leaf cut at a spring shop for each side.  That is where I got the clamps.  I had the springs sand blasted and powder coated.
JWW
2001 F150 SuperCrew
JWW
Postby mrollings53 on Tue May 01, 2012 12:07 am
If you've got the motor and tranny in; you could check by installing the driveshaft.  If it fits you're good, if not flip the springs around.
1969 F-250 Ranger Camper Special 390/C6/PS/PB/AC
1971 F-100 Sport Custom 360/C6/PS/PB
Common Sense is an Uncommon Virtue
mrollings53
Postby BobbyFord on Tue May 01, 2012 6:04 pm
Yes that is correct. If they were on backwards then the diff housing would not be centered directly below the bumpstops.
1972 Sport Custom Short bed 466/C6/3.50 trac-loc
1963 F100 Unibody 390/C6
1967 Mustang Fastback 390/4-speed
BobbyFord
Return to Suspension / Steering / Brakes
