crown vic swap parts list
Postby amos on Sun Apr 29, 2012 9:38 am
New guy here.
Im getting ready to do the swap on my 71 ford f100.   Im trying to make a part list and looking for help from those who have done it.
So far i have the ifs from a crown vic,  im pretty sure i need a steering colum from a 79 f150?  Correct me if I'm wrong
I really need some direction with the brakes and also the power steering.
Will the existing power steering pump from my 360 work?
Also what parts do I need to hook up the disc brakes?
Any input is greatly appreciated.
-Amos
amos
Re: crown vic swap parts list
Postby elgemcdlf on Sun Apr 29, 2012 1:42 pm
You will need 2 of these to connect your SAE brake lines to the metric hoses
I can not say for sure on the column. I have a '78/'79 tilt column in my truck that was there when i bought it. The current PS pump will work but stopped in gear (assuming you have an auto) the rpm level will be a bit low. Once you come off idle it will work just fine. Swapping out the PS pulley for a smaller diameter pulley may prove beneficial. I am in the middle of a 460 swap & with it I am putting in a Saginaw pump. It has a smaller pulley & I am hoping a bit more pressure at lower rpms than the pump I pulled out.
You will need some form of bridge in the PS pressure line. You need to keep the portion that goes into the rack but I have read a line from a Focus will work as well. I have also read that brake hoses from a '90's F100 will work with the calipers & you will not need the adapters as they are SAE on top. I can not verify that. I used the adapters. If you have not read it yet I can give you a couple threads to look at.
http://www.fordification.com/forum/viewtopic.php?f=22&t=37897&st=0&sk=t&sd=a
http://www.fordification.com/forum/viewtopic.php?f=22&t=54398&start=0
elgemcdlf
Postby amos on Tue May 01, 2012 9:34 pm
Thanks for the information ...i picked up the 271300 today..hopefully i have all the parts needed by next week,another trip to the salvage yard this weekend  :woohoo:
amos
Return to Suspension / Steering / Brakes
